Dykstras algorithm with bregman projections: A convergence proof, Optimization, vol.142, issue.4, pp.409-427, 2000. ,
DOI : 10.1007/BF01581245
Iterative bregman projections for regularized transportation problems. arXiv preprint arXiv, pp.1412-5154, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01096124
The relaxation method of finding the common point of convex sets and its application to the solution of problems in convex programming. USSR computational mathematics and mathematical physics, pp.200-217, 1967. ,
Polar factorization and monotone rearrangement of vector-valued functions, Communications on Pure and Applied Mathematics, vol.117, issue.4, pp.375-417, 1991. ,
DOI : 10.1002/cpa.3160440402
The full ci density of the li atom has been computed with a very large basis set with 8 s functions and up to k functions ,
Optimal-transport formulation of electronic density-functional theory, Physical Review A, vol.85, issue.6, p.502, 2012. ,
DOI : 10.1103/PhysRevA.85.062502
Matching for teams, Economic Theory, vol.11, issue.1, pp.397-418, 2010. ,
DOI : 10.1007/s00199-008-0415-z
URL : https://hal.archives-ouvertes.fr/hal-00661901
Multimarginal optimal transport maps for onedimensional repulsive costs. Canad, J. Math, vol.67, pp.350-368, 2015. ,
Asymptotic analysis of the exponential penalty trajectory in linear programming, Mathematical Programming, vol.27, issue.2, pp.169-187, 1994. ,
DOI : 10.1007/BF01582220
Density Functional Theory and Optimal Transportation with Coulomb Cost, Communications on Pure and Applied Mathematics, vol.12, issue.3, pp.548-599, 2013. ,
DOI : 10.1002/cpa.21437
URL : http://arxiv.org/abs/1104.0603
Infinite-body optimal transport with coulomb cost. Calculus of Variations and Partial Differential Equations pp, pp.1-26, 2013. ,
Sinkhorn distances: Lightspeed computation of optimal transport, Advances in Neural Information Processing Systems (NIPS) 26, pp.2292-2300, 2013. ,
Variational calculations on the helium isoelectronic sequence, Physical Review A, vol.29, issue.2, pp.980-982, 1984. ,
DOI : 10.1103/PhysRevA.29.980
N-density representability and the optimal transport limit of the Hohenberg-Kohn functional, The Journal of Chemical Physics, vol.139, issue.16, p.109, 2013. ,
DOI : 10.1063/1.4821351
Matching with Trade-Offs: Revealed Preferences Over Competing Characteristics, SSRN Electronic Journal, 2009. ,
DOI : 10.2139/ssrn.1487307
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.184.1057
Optimal maps for the multidimensional Monge-Kantorovich problem DOI 10.1002/(SICI), 1<23::AID-CPA2>3.0.CO;2-H. URL http1<23::AID-CPA2>3.0.CO, pp.23-451097, 1998. ,
DOI : 10.1002/(sici)1097-0312(199801)51:1<23::aid-cpa2>3.0.co;2-h
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.116.1489
Remarks on multi-marginal symmetric Monge-Kantorovich problems, Discrete Contin. Dyn. Syst, vol.34, issue.4, pp.1465-1480, 2014. ,
Geometric Applications of the Split Bregman Method: Segmentation and Surface Reconstruction, Journal of Scientific Computing, vol.80, issue.3, pp.272-293, 2010. ,
DOI : 10.1007/s10915-009-9331-z
Inhomogeneous Electron Gas, Physical Review, vol.136, issue.3B, pp.864-871, 1964. ,
DOI : 10.1103/PhysRev.136.B864
On the transfer of masses (in russian), Doklady Akademii Nauk, vol.37, issue.2, pp.227-229, 1942. ,
Self-Consistent Equations Including Exchange and Correlation Effects, Physical Review, vol.140, issue.4A, pp.1133-1138, 1965. ,
DOI : 10.1103/PhysRev.140.A1133
Strong Correlation in Kohn-Sham Density Functional Theory, Physical Review Letters, vol.109, issue.24, p.402, 2012. ,
DOI : 10.1103/PhysRevLett.109.246402
Kantorovich dual solution for strictly correlated electrons in atoms and molecules, Physical Review B, vol.87, issue.12, p.106, 2013. ,
DOI : 10.1103/PhysRevB.87.125106
Mémoire sur la théorie des déblais et des remblais, 1781. ,
The geometry of orthogonal spaces, Functional Operators. Measures and integrals, vol.1, issue.21, p.22, 1950. ,
On Rings of Operators. Reduction Theory, The Annals of Mathematics, vol.50, issue.2, pp.401-485, 1949. ,
DOI : 10.2307/1969463
private communication. paper in preparation 28. Pass, B.: Uniqueness and Monge solutions in the multimarginal optimal transportation problem, SIAM Journal on Mathematical Analysis, vol.4343, issue.61, pp.2758-2775, 2011. ,
Multi-marginal optimal transport and multi-agent matching problems: Uniqueness and structure of solutions, Discrete and Continuous Dynamical Systems, vol.34, issue.4, pp.1623-1639, 2014. ,
DOI : 10.3934/dcds.2014.34.1623
Convergence of the Iterative Proportional Fitting Procedure, The Annals of Statistics, vol.23, issue.4, pp.1160-1174, 1995. ,
DOI : 10.1214/aos/1176324703
Closedness of Sum Spaces andthe Generalized Schr??dinger Problem, Theory of Probability & Its Applications, vol.42, issue.3, pp.483-494, 1998. ,
DOI : 10.1137/S0040585X97976301
Uber die umkehrung der naturgesetze, Sitzungsberichte Preuss. Akad. Wiss. Berlin. Phys. Math, vol.144, pp.144-153, 1931. ,
Strictly correlated electrons in densityfunctional theory: A general formulation with applications to spherical densities, Phys. Rev. A, vol.75, issue.042, p.511, 2007. ,
Topics in Optimal Transportation Graduate Studies in Mathematics Series, 2003. ,
Optimal transport: old and new, 2009. ,
DOI : 10.1007/978-3-540-71050-9
