Theory and design of high order sound field microphones using spherical microphone array, IEEE International Conference on Acoustics Speech and Signal Processing, pp.1949-1952, 2002. ,
DOI : 10.1109/ICASSP.2002.5745011
Measurements of directional properties of reverberant sound fields in rooms using a spherical microphone array, The Journal of the Acoustical Society of America, vol.116, issue.4, pp.2138-2148, 2004. ,
DOI : 10.1121/1.1787525
A highly scalable spherical microphone array based on an orthonormal decomposition of the soundfield, Acoustics, Speech and Signal Processing IEEE International Conference on, pp.1781-1784, 2002. ,
Effect of directional elements on the directional response of circular antenna arrays, Microwaves, Optics and Antennas, pp.18-22, 1982. ,
DOI : 10.1049/ip-h-1.1982.0004
Beamforming for a circular microphone array mounted on spherically shaped objects, The Journal of the Acoustical Society of America, vol.109, issue.1, pp.185-193, 2001. ,
DOI : 10.1121/1.1329616
Open-Sphere Designs for Spherical Microphone Arrays, IEEE Transactions on Audio, Speech and Language Processing, vol.15, issue.2, pp.727-732, 2007. ,
DOI : 10.1109/TASL.2006.881671
Acoustic holography with a concentric rigid and open spherical microphone array, 2009 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.2173-2176, 2009. ,
DOI : 10.1109/ICASSP.2009.4960048
Design, Optimization and Evaluation of a Dual-Radius Spherical Microphone Array, Audio, Speech, and Language Processing, pp.193-204, 2014. ,
DOI : 10.1109/TASLP.2013.2286920
The Spherical-Shell Microphone Array, IEEE Transactions on Audio, Speech, and Language Processing, vol.16, issue.4, pp.740-747, 2008. ,
DOI : 10.1109/TASL.2008.920059
Alternatives to spherical microphone arrays: Hybrid geometries, 2009 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.81-84, 2009. ,
DOI : 10.1109/ICASSP.2009.4959525
Double sided cone array for spherical harmonic analysis of wavefields, 2010 IEEE International Conference on Acoustics, Speech and Signal Processing, pp.77-80, 2010. ,
DOI : 10.1109/ICASSP.2010.5496193
Spindle-Torus Sampling for an Efficient-Scanning Spherical Microphone Array, Acta Acustica united with Acustica, vol.98, issue.1, pp.83-90, 2012. ,
DOI : 10.3813/AAA.918494
Low Frequency Interpolation of Room Impulse Responses Using Compressed Sensing, IEEE/ACM Transactions on Audio, Speech, and Language Processing, vol.22, issue.1, pp.205-216, 2014. ,
DOI : 10.1109/TASLP.2013.2286922
URL : https://hal.archives-ouvertes.fr/hal-01152472
Bessel Nulls Recovery in Spherical Microphone Arrays for Time-Limited Signals, Audio, Speech, and Language Processing, pp.2430-2438, 2011. ,
DOI : 10.1109/TASL.2011.2136338
Design of a robust open spherical microphone array, 2014 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.6860-6863, 2014. ,
DOI : 10.1109/ICASSP.2014.6854919
URL : https://hal.archives-ouvertes.fr/hal-01106926
Plane wave approximation of homogeneous Helmholtz solutions, Zeitschrift für Angewandte Mathematik und Physik (ZAMP), pp.809-837, 2011. ,
DOI : 10.1007/s00033-011-0147-y
Operator adapted spectral element methods I: harmonic and generalized harmonic polynomials, Zeitschrift für Mathematik und Physik, pp.35-69, 1901. ,
DOI : 10.1007/s002110050463
On the Stability and Accuracy of Least Squares Approximations, 10th International Conference on Sampling Theory and Applications, pp.819-834, 2013. ,
DOI : 10.1007/s10208-013-9142-3
URL : https://hal.archives-ouvertes.fr/hal-01432960
The Uniform Error of Hyperinterpolation on the Sphere, Advances in Multivariate Approximation, pp.289-306, 1998. ,
How good can polynomial interpolation on the sphere be?, Advances in Computational Mathematics, vol.14, issue.3, pp.195-226, 2001. ,
DOI : 10.1023/A:1016630227163
A general multipurpose interpolation procedure: the magic points, Communications on Pure and Applied Analysis, vol.8, issue.1, pp.383-404, 2009. ,
DOI : 10.3934/cpaa.2009.8.383
URL : https://hal.archives-ouvertes.fr/hal-00174797
Dissipation in deforming chaotic billiards, 2000. ,
Reviving the Method of Particular Solutions, SIAM Review, vol.47, issue.3, pp.469-491, 2005. ,
DOI : 10.1137/S0036144503437336
After working towards his PhD at Institut Langevin in Paris, and a postdoctoral position with the Mathematics and Signal Processing group of the Acoustics Research Institute of the Austrian Academy of Sciences in Vienna, he is now Associate Professor with Centrale- Supélec His main research interests include sparse representation of acoustical fields, inverse problems and numerical analysis in acoustics, 2009. ,
D in engineering mathematics in 2000 at the Technical University of Vienna After working at the Institute for Applied and Numerical Mathematics at the TU-Vienna he joined the Acoustics Research Institute of the Austrian Academy of Sciences His main research interests is focused on models and simulation of wave propagation and wave scattering, 2004. ,
