Room helps: Acoustic localization with finite elements, 2012 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), 2012. ,
DOI : 10.1109/ICASSP.2012.6288453
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.699.2583
Source localization in reverberant environments using sparse optimization, Proc. IEEE Int. Conf. Acoustics, Speech, and Signal Processing (ICASSP), 2013. ,
Time reversal of ultrasonic fields. I. Basic principles, IEEE Transactions on Ultrasonics, Ferroelectrics and Frequency Control, vol.39, issue.5, pp.555-566, 1992. ,
DOI : 10.1109/58.156174
In solid localization of finger impacts using acoustic time-reversal process, Applied Physics Letters, vol.87, issue.20, p.204104, 2005. ,
DOI : 10.1063/1.2130720
Signal reconstruction in sensor arrays using sparse representations, Signal Processing, vol.86, issue.3, pp.624-638, 2006. ,
DOI : 10.1016/j.sigpro.2005.05.033
Physics-driven structured cosparse modeling for source localization, 2012 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), 2012. ,
DOI : 10.1109/ICASSP.2012.6289141
URL : https://hal.archives-ouvertes.fr/hal-00659405
The cosparse analysis model and algorithms, Applied and Computational Harmonic Analysis, vol.34, issue.1, pp.30-56, 2013. ,
DOI : 10.1016/j.acha.2012.03.006
URL : https://hal.archives-ouvertes.fr/inria-00602205
New methods for solving elliptic equations, 1967. ,
A survey of I. N. Vekua's theory of elliptic partial differential equations with analytic coefficients, Zeitschrift für Angewandte Mathematik und Physik (ZAMP), pp.169-203, 1007. ,
DOI : 10.1007/BF01600500
On the Rate of Convergence of the Bergman???Vekua Method for the Numerical Solution of Elliptic Boundary Value Problems, SIAM Journal on Numerical Analysis, vol.11, issue.3, pp.654-680, 1974. ,
DOI : 10.1137/0711053
Plane wave approximation of homogeneous Helmholtz solutions, Zeitschrift für Angewandte Mathematik und Physik (ZAMP), pp.809-837 ,
DOI : 10.1007/s00033-011-0147-y
Greed is Good: Algorithmic Results for Sparse Approximation, IEEE Transactions on Information Theory, vol.50, issue.10, pp.2231-2242, 2004. ,
DOI : 10.1109/TIT.2004.834793
URL : http://authors.library.caltech.edu/9035/1/TROieeetit04a.pdf
Reconstruction of solutions to the Helmholtz equation from punctual measurements, 10th International Conference on Sampling Theory and Applications, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00842798
A closed form solution to the microphone position self-calibration problem, 2012 IEEE International Conference on Acoustics, Speech and Signal Processing (ICASSP), pp.2597-2600, 2012. ,
DOI : 10.1109/ICASSP.2012.6288448
