Nitsche-XFEM for the coupling of an incompressible fluid with immersed thin-walled structures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Methods in Applied Mechanics and Engineering Année : 2016
In this paper we introduce a Nitsche-XFEM method for fluid-structure interaction problems involving a thin-walled elastic structure (Lagrangian formalism) immersed in an incompressible viscous fluid (Eulerian formalism). The fluid domain is discretized with an unstructured mesh not fitted to the solid mid-surface mesh. Weak and strong discontinuities across the interface are allowed for the velocity and pressure, respectively. The fluid-solid coupling is enforced consistently using a variant of Nitsche's method with cut-elements. Robustness with respect to arbitrary interface intersections is guaranteed through suitable stabilization. Several coupling schemes with different degrees of fluid-solid time splitting (implicit, semi-implicit and explicit) are investigated. A series of numerical tests in 2D, involving static and moving interfaces, illustrates the performance of the different methods proposed.
RR-8723.pdf (39.67 Mo) Télécharger le fichier
hal-01149225 , version 1 (06-05-2015)
hal-01149225 , version 2 (07-05-2015)
hal-01149225 , version 3 (17-12-2015)
Frédéric Alauzet, Benoit Fabrèges, Miguel Angel Fernández, Mikel Landajuela. Nitsche-XFEM for the coupling of an incompressible fluid with immersed thin-walled structures. Computer Methods in Applied Mechanics and Engineering, 2016, 301, pp.300-335. ⟨10.1016/j.cma.2015.12.015⟩. ⟨hal-01149225v3⟩
860 Consultations
489 Téléchargements
