A changing-topology moving mesh technique for large displacements, Engineering with Computers, vol.222, issue.13, pp.175-200, 2014. ,
DOI : 10.1007/s00366-013-0340-z
URL : https://hal.archives-ouvertes.fr/hal-01114995
P1-conservative solution interpolation on unstructured triangular meshes, International Journal for Numerical Methods in Engineering, vol.27, issue.2, pp.1552-1588, 2010. ,
DOI : 10.1002/nme.2951
URL : https://hal.archives-ouvertes.fr/inria-00354509
A low-order local projection method for the incompressible Navier???Stokes equations in two- and three-dimensions, IMA Journal of Numerical Analysis, 2015. ,
DOI : 10.1093/imanum/drv004
Fluid???structure interaction and multi-body contact: Application to aortic valves, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.45-46, pp.45-463603, 2009. ,
DOI : 10.1016/j.cma.2008.09.012
URL : https://hal.archives-ouvertes.fr/inria-00542238
A fictitious domain/mortar element method for fluid-structure interaction, International Journal for Numerical Methods in Fluids, vol.79, issue.7, pp.743-761, 2001. ,
DOI : 10.1002/1097-0363(20010415)35:7<743::AID-FLD109>3.0.CO;2-A
A Nitsche extended finite element method for incompressible elasticity with discontinuous modulus of elasticity, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.41-44, pp.41-443352, 2009. ,
DOI : 10.1016/j.cma.2009.06.017
URL : https://hal.archives-ouvertes.fr/inria-00341737
FINITE ELEMENT APPROACH TO IMMERSED BOUNDARY METHOD WITH DIFFERENT FLUID AND SOLID DENSITIES, Mathematical Models and Methods in Applied Sciences, vol.21, issue.12, pp.2523-2550, 2011. ,
DOI : 10.1142/S0218202511005829
The Finite Element Immersed Boundary Method with Distributed Lagrange Multiplier, SIAM Journal on Numerical Analysis, vol.53, issue.6, pp.2584-2604, 2015. ,
DOI : 10.1137/140978399
Stabilized finite element methods for the generalized Oseen problem, Computer Methods in Applied Mechanics and Engineering, vol.196, issue.4-6, pp.4-6853, 2007. ,
DOI : 10.1016/j.cma.2006.07.011
On the Stabilization of Finite Element Approximations of the Stokes Equations, Efficient solutions of elliptic systems, pp.11-19, 1984. ,
DOI : 10.1007/978-3-663-14169-3_2
Streamline upwind/Petrov-Galerkin formulations for convection dominated flows with particular emphasis on the incompressible Navier-Stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.32, issue.1-3, pp.1-3199, 1982. ,
DOI : 10.1016/0045-7825(82)90071-8
Ghost penalty, Comptes Rendus Mathematique, vol.348, issue.21-22, pp.21-221217, 2010. ,
DOI : 10.1016/j.crma.2010.10.006
URL : https://hal.archives-ouvertes.fr/inria-00543248
CutFEM: Discretizing geometry and partial differential equations, International Journal for Numerical Methods in Engineering, vol.128, issue.1, 2015. ,
DOI : 10.1002/nme.4823
Continuous interior penalty finite element method for the time-dependent Navier???Stokes equations: space discretization and convergence, Numerische Mathematik, vol.33, issue.1, pp.39-77, 2007. ,
DOI : 10.1007/s00211-007-0070-5
URL : https://hal.archives-ouvertes.fr/hal-00715243
Stabilization of explicit coupling in fluid???structure interaction involving fluid incompressibility, Computer Methods in Applied Mechanics and Engineering, vol.198, issue.5-8, pp.5-8766, 2009. ,
DOI : 10.1016/j.cma.2008.10.012
URL : https://hal.archives-ouvertes.fr/inria-00247409
Explicit strategies for incompressible fluid-structure interaction problems: Nitsche type mortaring versus Robin-Robin coupling, International Journal for Numerical Methods in Engineering, vol.13, issue.1, pp.739-758, 2014. ,
DOI : 10.1002/nme.4607
URL : https://hal.archives-ouvertes.fr/hal-00819948
An unfitted Nitsche method for incompressible fluid???structure interaction using overlapping meshes, Computer Methods in Applied Mechanics and Engineering, vol.279, pp.497-514, 2014. ,
DOI : 10.1016/j.cma.2014.07.007
URL : https://hal.archives-ouvertes.fr/hal-00918272
Continuous Interior Penalty Finite Element Method for Oseen's Equations, SIAM Journal on Numerical Analysis, vol.44, issue.3, pp.1248-1274, 2006. ,
DOI : 10.1137/040617686
Fictitious domain finite element methods using cut elements: II. A stabilized Nitsche method, Applied Numerical Mathematics, vol.62, issue.4, pp.328-341, 2012. ,
DOI : 10.1016/j.apnum.2011.01.008
Fictitious domain methods using cut elements: III. A stabilized Nitsche method for Stokes??? problem, ESAIM: Mathematical Modelling and Numerical Analysis, vol.48, issue.3, pp.859-874, 2014. ,
DOI : 10.1051/m2an/2013123
The Finite Element Analysis of Shells -Fundamentals, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00839738
Stabilized finite element approximation of transient incompressible flows using orthogonal subscales, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.39-40, pp.39-404295, 2002. ,
DOI : 10.1016/S0045-7825(02)00337-7
Eulerian formulation and level set models for incompressible fluid-structure interaction, ESAIM: Mathematical Modelling and Numerical Analysis, vol.42, issue.3, pp.471-492, 2008. ,
DOI : 10.1051/m2an:2008013
URL : https://hal.archives-ouvertes.fr/hal-00297711
Mathematical aspects of discontinuous Galerkin methods, Mathematics & Applications, vol.69 ,
DOI : 10.1007/978-3-642-22980-0
On singularities in the solution of three-dimensional Stokes flow and incompressible elasticity problems with corners, International Journal for Numerical Methods in Engineering, vol.60, issue.4, pp.773-801, 2004. ,
DOI : 10.1002/nme.986
A partitioned fluid???structure algorithm for elastic thin valves with contact, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.19-20, pp.19-201750, 2008. ,
DOI : 10.1016/j.cma.2007.03.019
URL : https://hal.archives-ouvertes.fr/hal-00701780
Imposing Dirichlet boundary conditions with Nitsche's method and spline-based finite elements, International Journal for Numerical Methods in Engineering, vol.17, issue.2, pp.877-898, 2010. ,
DOI : 10.1002/nme.2863
Coupling an Eulerian Fluid Calculation to a Lagrangian Solid Calculation with the Ghost Fluid Method, Journal of Computational Physics, vol.175, issue.1, pp.200-224, 2002. ,
DOI : 10.1006/jcph.2001.6935
Incremental displacement-correction schemes for incompressible fluid-structure interaction, Numerische Mathematik, vol.17, issue.6, pp.21-65, 2013. ,
DOI : 10.1007/s00211-012-0481-9
Splitting schemes for incompressible fluid/thin-walled structure interaction with unfitted meshes, Comptes Rendus Mathematique, vol.353, issue.7 ,
DOI : 10.1016/j.crma.2015.04.003
Explicit Robin???Neumann schemes for the coupling of incompressible fluids with thin-walled structures, Computer Methods in Applied Mechanics and Engineering, vol.267, pp.566-593, 2013. ,
DOI : 10.1016/j.cma.2013.09.020
Mesh generation. Application to finite elements, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00073738
The extended/generalized finite element method: An overview of the method and its applications, International Journal for Numerical Methods in Engineering, vol.76, issue.5, pp.253-304, 2010. ,
DOI : 10.1002/nme.2914
On time integration in the XFEM, International Journal for Numerical Methods in Engineering, vol.29, issue.3, pp.69-93, 2009. ,
DOI : 10.1002/fld.1901.2008
Stabilization by Local Projection for??Convection???Diffusion and Incompressible Flow Problems, Journal of Scientific Computing, vol.33, issue.4, pp.326-342, 2010. ,
DOI : 10.1007/s10915-008-9259-8
Parallel multilevel solution of nonlinear shell structures, Computer Methods in Applied Mechanics and Engineering, vol.194, issue.21-24, pp.21-242513, 2005. ,
DOI : 10.1016/j.cma.2004.07.043
?Ultimate? robustness in meshing an arbitrary polyhedron, International Journal for Numerical Methods in Engineering, vol.25, issue.7, pp.1061-1089, 2003. ,
DOI : 10.1002/nme.808
An eXtended Finite Element Method/Lagrange multiplier based approach for fluid???structure interaction, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.19-20, pp.19-201699, 2008. ,
DOI : 10.1016/j.cma.2007.07.002
A distributed Lagrange multiplier/fictitious domain method for particulate flows, International Journal of Multiphase Flow, vol.25, issue.5, pp.755-794, 1999. ,
DOI : 10.1016/S0301-9322(98)00048-2
An unfitted finite element method, based on Nitsche???s method, for elliptic interface problems, Computer Methods in Applied Mechanics and Engineering, vol.191, issue.47-48, pp.47-485537, 2002. ,
DOI : 10.1016/S0045-7825(02)00524-8
URL : https://hal.archives-ouvertes.fr/hal-01352903
A finite element method for the simulation of strong and weak discontinuities in solid mechanics, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.33-35, pp.33-353523, 2004. ,
DOI : 10.1016/j.cma.2003.12.041
Nitsche's method for interface problems in computa-tional mechanics, GAMM-Mitteilungen, vol.15, issue.2, pp.183-206, 2005. ,
DOI : 10.1002/gamm.201490018
Nitsche's method combined with space???time finite elements for ALE fluid???structure interaction problems, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.39-41, pp.39-414195, 2004. ,
DOI : 10.1016/j.cma.2003.09.029
What are C and h?: Inequalities for the analysis and design of finite element methods, Computer Methods in Applied Mechanics and Engineering, vol.97, issue.2, pp.157-192, 1992. ,
DOI : 10.1016/0045-7825(92)90162-D
A new finite element formulation for computational fluid dynamics: V. Circumventing the babu??ka-brezzi condition: a stable Petrov-Galerkin formulation of the stokes problem accommodating equal-order interpolations, Computer Methods in Applied Mechanics and Engineering, vol.59, issue.1, pp.85-99, 1986. ,
DOI : 10.1016/0045-7825(86)90025-3
An immersogeometric variational framework for fluid???structure interaction: Application to bioprosthetic heart valves, Computer Methods in Applied Mechanics and Engineering, vol.284, pp.1005-1053, 2015. ,
DOI : 10.1016/j.cma.2014.10.040
An Eulerian???Lagrangian method for fluid???structure interaction based on level sets, Computer Methods in Applied Mechanics and Engineering, vol.195, issue.17-18, pp.17-182070, 2006. ,
DOI : 10.1016/j.cma.2005.02.025
Nitsche-XFEM with Streamline Diffusion Stabilization for a Two-Phase Mass Transport Problem, SIAM Journal on Scientific Computing, vol.34, issue.5, pp.2740-2759, 2012. ,
DOI : 10.1137/110855235
Analysis of a Nitsche XFEM-DG Discretization for a Class of Two-Phase Mass Transport Problems, SIAM Journal on Numerical Analysis, vol.51, issue.2, pp.958-983, 2013. ,
DOI : 10.1137/120875260
Numerical Simulation of Sailing Boats: Dynamics, FSI, and Shape Optimization, Variational Analysis and Aerospace Engineering: Mathematical Challenges for Aerospace Design, pp.339-377, 2012. ,
DOI : 10.1007/978-1-4614-2435-2_15
A Stabilized Nitsche Fictitious Domain Method for the Stokes Problem, Journal of Scientific Computing, vol.207, issue.1, pp.604-628, 2014. ,
DOI : 10.1007/s10915-014-9838-9
Efficient Implementation of Finite Element Methods on Nonmatching and Overlapping Meshes in Three Dimensions, SIAM Journal on Scientific Computing, vol.35, issue.1, pp.23-47, 2013. ,
DOI : 10.1137/11085949X
Interface handling for three-dimensional higher-order XFEM-computations in fluid-structure interaction, International Journal for Numerical Methods in Engineering, vol.22, issue.1, pp.846-869, 2009. ,
DOI : 10.1002/nme.2600
Fish and Flag ??? Exploring Fluid-Structure Interaction during Undulatory Swimming in Fish, 6th World Congress of Biomechanics, pp.44-47, 2010. ,
DOI : 10.1007/978-3-642-14515-5_12
Unconditionally stable discretizations of the immersed boundary equations, Journal of Computational Physics, vol.222, issue.2, pp.702-719, 2007. ,
DOI : 10.1016/j.jcp.2006.08.004
??ber ein Variationsprinzip zur L??sung von Dirichlet-Problemen bei Verwendung von Teilr??umen, die keinen Randbedingungen unterworfen sind, Abhandlungen aus dem Mathematischen Seminar der Universit??t Hamburg, vol.12, issue.1, pp.9-15, 1971. ,
DOI : 10.1007/BF02995904
The immersed boundary method, Acta Numer, vol.11, pp.479-517, 2002. ,
Computational hydrodynamics of capsules and biological cells, CRC Mathematical and Computational Biology, vol.20103131, 2010. ,
DOI : 10.1201/EBK1439820056
A Fully Eulerian formulation for fluid???structure-interaction problems, Journal of Computational Physics, vol.233, pp.227-240, 2013. ,
DOI : 10.1016/j.jcp.2012.08.047
Weak coupling for isogeometric analysis of non-matching and trimmed multi-patch geometries, Computer Methods in Applied Mechanics and Engineering, vol.269, pp.46-71, 2014. ,
DOI : 10.1016/j.cma.2013.10.009
LLM and X-FEM based interface modeling of fluid???thin structure interactions on a non-interface-fitted mesh, Computational Mechanics, vol.408, issue.EM3, pp.319-332, 2011. ,
DOI : 10.1007/s00466-011-0600-y
A new face-oriented stabilized XFEM approach for 2D and 3D incompressible Navier???Stokes equations, Computer Methods in Applied Mechanics and Engineering, vol.276, pp.233-265, 2014. ,
DOI : 10.1016/j.cma.2014.02.014
Automatic mesh update with the solid-extension mesh moving technique, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.21-22, pp.21-222019, 2004. ,
DOI : 10.1016/j.cma.2003.12.046
On some techniques for approximating boundary conditions in the finite element method, Journal of Computational and Applied Mathematics, vol.63, issue.1-3, pp.139-148, 1995. ,
DOI : 10.1016/0377-0427(95)00057-7
An accurate, robust, and easy-to-implement method for integration over arbitrary polyhedra: Application to embedded interface methods, Journal of Computational Physics, vol.273, pp.393-415, 2014. ,
DOI : 10.1016/j.jcp.2014.05.019
Computational Methods for Parachute Fluid???Structure Interactions, Archives of Computational Methods in Engineering, vol.20, issue.1, pp.125-169, 2012. ,
DOI : 10.1007/s11831-012-9070-4
Space???time interface-tracking with topology change (ST-TC), Computational Mechanics, vol.43, issue.4, pp.955-971, 2014. ,
DOI : 10.1007/s00466-013-0935-7
Stabilized Finite Element Formulations for Incompressible Flow Computations, Advances in applied mechanics, pp.1-44, 1992. ,
DOI : 10.1016/S0065-2156(08)70153-4
Fluid???structure interaction involving large deformations: 3D simulations and applications to biological systems, Journal of Computational Physics, vol.258, pp.451-469, 2014. ,
DOI : 10.1016/j.jcp.2013.10.047
Computational algorithms for tracking dynamic fluid-structure interfaces in embedded boundary methods, International Journal for Numerical Methods in Fluids, vol.195, issue.4, pp.515-535, 2012. ,
DOI : 10.1002/fld.3659
Fluid-structure interactions using different mesh motion techniques, Computers & Structures, vol.89, issue.13-14, pp.13-141456, 2011. ,
DOI : 10.1016/j.compstruc.2011.02.019
Grid movement techniques and their influence on laminar fluid???structure interaction computations, Journal of Fluids and Structures, vol.24, issue.6, pp.819-832, 2008. ,
DOI : 10.1016/j.jfluidstructs.2007.12.002
Immersed finite element method, Computer Methods in Applied Mechanics and Engineering, vol.193, issue.21-22, pp.21-222051, 2004. ,
DOI : 10.1016/j.cma.2003.12.044
The enriched space???time finite element method (EST) for simultaneous solution of fluid???structure interaction, International Journal for Numerical Methods in Engineering, vol.90, issue.3, pp.305-334, 2008. ,
DOI : 10.1002/nme.2258
URL : https://hal.archives-ouvertes.fr/hal-01371129
Analysis of backward Euler/extended finite element discretization of parabolic problems with moving interfaces, Computer Methods in Applied Mechanics and Engineering, vol.258, pp.152-165, 2013. ,
DOI : 10.1016/j.cma.2013.02.010
23 3.2.2 Integrals with discontinuous functions at different time levels, p.26 ,
31 4.2.1 Idealized closed valve, p.38 ,
