On the Use of Formal Grammars to Predict HPC I/O Behaviors - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
De l'Utilisation de Grammaires Formelles pour Prédire le Comportement des E/S en Calcul Hautes Performances
The increasing gap between the computation performance of post-petascale machines and the performance of their I/O subsystem has motivated many I/O optimizations including prefetching, caching, and scheduling. In order to further improve these techniques, modeling and predicting spatial and temporal I/O patterns of HPC applications as they run has become crucial. In this paper we present Omnisc'IO, an approach that builds a grammar-based model of the I/O behavior of HPC applications and uses it to predict when future I/O operations will occur, and where and how much data will be accessed. To infer grammars, Omnisc'IO is based on StarSequitur, a novel algorithm extending Nevill-Manning's Sequitur algorithm. Omnisc'IO is transparently integrated into the POSIX and MPI I/O stacks and does not require any modification in applications or higher-level I/O libraries. It works without any prior knowledge of the application and converges to accurate predictions of any \emph{N} future I/O operations within a couple of iterations. Its implementation is efficient in both computation time and memory footprint.
RR-8725.pdf (1.63 Mo) Télécharger le fichier
hal-01149941 , version 1 (07-05-2015)
hal-01149941 , version 2 (14-08-2015)
  • HAL Id : hal-01149941 , version 1
Matthieu Dorier, Shadi Ibrahim, Gabriel Antoniu, Rob Ross. On the Use of Formal Grammars to Predict HPC I/O Behaviors. [Research Report] RR-8725, ENS Rennes; Inria Rennes Bretagne Atlantique; Argonne National Laboratory. 2015. ⟨hal-01149941v1⟩
575 Consultations
244 Téléchargements
