Abstract : The increasing gap between the computation performance of post-petascale machines and the performance of their I/O subsystem has motivated many I/O optimizations including prefetching, caching, and scheduling. In order to further improve these techniques, modeling and predicting spatial and temporal I/O patterns of HPC applications as they run has become crucial. In this paper we present Omnisc'IO, an approach that builds a grammar-based model of the I/O behavior of HPC applications and uses it to predict when future I/O operations will occur, and where and how much data will be accessed. To infer grammars, Omnisc'IO is based on StarSequitur, a novel algorithm extending Nevill-Manning's Sequitur algorithm. Omnisc'IO is transparently integrated into the POSIX and MPI I/O stacks and does not require any modification in applications or higher-level I/O libraries. It works without any prior knowledge of the application and converges to accurate predictions of any \emph{N} future I/O operations within a couple of iterations. Its implementation is efficient in both computation time and memory footprint.
https://hal.inria.fr/hal-01149941 Contributor : Matthieu DorierConnect in order to contact the contributor Submitted on : Friday, August 14, 2015 - 3:38:48 PM Last modification on : Wednesday, February 2, 2022 - 3:50:51 PM Long-term archiving on: : Wednesday, April 26, 2017 - 10:05:19 AM
Matthieu Dorier, Shadi Ibrahim, Gabriel Antoniu, Rob Ross. On the Use of Formal Grammars to Predict HPC I/O Behaviors. [Research Report] RR-8725, ENS Rennes; Inria Rennes Bretagne Atlantique; Argonne National Laboratory; INRIA. 2015. ⟨hal-01149941v2⟩
