Classification of Multiple Sclerosis Lesions using Adaptive Dictionary Learning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computerized Medical Imaging and Graphics Année : 2015
This paper presents a sparse representation and an adaptive dictionary learning based method for automated classification of Multiple Sclerosis (MS) lesions in Magnetic Resonance (MR) images. Manual delineation of MS lesions is a time-consuming task, requiring neuroradiology experts to analyze huge volume of MR data. This, in addition to the high intra-and inter-observer variability necessitates the requirement of automated MS lesion classification methods. Among many image representation models and classification methods that can be used for such purpose, we investigate the use of sparse modeling. In the recent years, sparse representation has evolved as a tool in modeling data using a few basis elements of an over-complete dictionary and has found applications in many image processing tasks including classification. We propose a supervised classification approach by learning dictionaries specific to the lesions and individual healthy brain tissues, which include White Matter (WM), Gray Matter (GM) and Cerebrospinal Fluid (CSF). The size of the dictionaries learned for each class plays a major role in data representation but it is an even more crucial element in the case of competitive classification. Our approach adapts the size of the dictionary for each class, depending on the complexity of the underlying data. The algorithm is validated using 52 multi-sequence MR images acquired from 13 MS patients. The results demonstrate the effectiveness of our approach in MS lesion classification.
Hrishikesh_CMIG_Final.pdf (1.94 Mo) Télécharger le fichier
hal-01151695 , version 1 (13-05-2015)
hal-01151695 , version 2 (22-05-2015)
Hrishikesh Deshpande, Pierre Maurel, Christian Barillot. Classification of Multiple Sclerosis Lesions using Adaptive Dictionary Learning. Computerized Medical Imaging and Graphics, 2015, pp.1-15. ⟨10.1016/j.compmedimag.2015.05.003⟩. ⟨hal-01151695v2⟩
317 Consultations
722 Téléchargements
