Linking Past to Present: Discovering Style in Two Centuries of Architecture - Archive ouverte HAL Access content directly
Conference Papers Year :
With vast quantities of imagery now available online, researchers have begun to explore whether visual patterns can be discovered automatically. Here we consider the particular domain of architecture, using huge collections of street-level imagery to find visual patterns that correspond to semantic-level architectural elements distinctive to particular time periods. We use this analysis both to date buildings, as well as to discover how functionally-similar architectural elements (e.g. windows, doors, balconies , etc.) have changed over time due to evolving styles. We validate the methods by combining a large dataset of nearly 150,000 Google Street View images from Paris with a cadastre map to infer approximate construction date for each facade. Not only could our analysis be used for dating or geo-localizing buildings based on architectural features, but it also could give architects and historians new tools for confirming known theories or even discovering new ones.
Lee15.pdf (5.06 Mo) Télécharger le fichier
Dates and versions
hal-01152482 , version 1 (17-05-2015)
Identifiers
  • HAL Id : hal-01152482 , version 1
Cite
Stefan Lee, Nicolas Maisonneuve, David Crandall, Alexei A. Efros, Josef Sivic. Linking Past to Present: Discovering Style in Two Centuries of Architecture. IEEE International Conference on Computational Photography, Apr 2015, Houston, United States. ⟨hal-01152482⟩
580 View
396 Download
Share
