New interface
Conference papers
Exploiting the Phase in Diffusion MRI for Microstructure Recovery: Towards Axonal Tortuosity via Asymmetric Diffusion Processes
Marco Pizzolato 1, * Demian Wassermann 1 Timothé Boutelier 2 Rachid Deriche 1
* Corresponding author
1 ATHENA - Computational Imaging of the Central Nervous System
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : Microstructure recovery procedures via Diffusion-Weighted Magnetic Resonance Imaging (DW-MRI) usually discard the signal's phase, assuming symmetry in the underlying diffusion process. We propose to recover the Ensemble Average Propagator (EAP) directly from the complex DW signal in order to describe also eventual diffusional asymmetry, thus obtaining an asymmetric EAP. The asymmetry of the EAP is then related to tortuosity of undulated white matter axons, which are found in pathological scenarios associated with axonal elongation or compression. We derive a model of the EAP for this geometry and quantify its asymmetry. Results show that the EAP obtained when accounting for the DW signal's phase provides useful microstructural information in such pathological scenarios. Furthermore, we validate these results in-silico through 3D Monte-Carlo simulations of white matter tissue that has experienced different degrees of elongation/compression.
Complete list of metadata
Cited literature [10 references]  Display  Hide  Download
https://hal.inria.fr/hal-01152672
Contributor : Marco Pizzolato Connect in order to contact the contributor
Submitted on : Tuesday, May 19, 2015 - 2:14:30 PM
Last modification on : Saturday, June 25, 2022 - 11:16:36 PM
Long-term archiving on: : Thursday, April 20, 2017 - 1:33:23 AM
File
Pizzolato et al - Exploiting t...
Identifiers
Collections
Citation
Marco Pizzolato, Demian Wassermann, Timothé Boutelier, Rachid Deriche. Exploiting the Phase in Diffusion MRI for Microstructure Recovery: Towards Axonal Tortuosity via Asymmetric Diffusion Processes. Medical Image Computing and Computer Assisted Intervention, 2015, Munich, Germany. ⟨10.1007/978-3-319-24553-9_14⟩. ⟨hal-01152672⟩
Share
Metrics
Record views
145
Files downloads
205
