Christopher Alexander. A Pattern Language, 1977. ,
Process Pattern : Building Large-Scale Systems Using Object Technology, 1998. ,
Recovery Blocks in Action: A System Supporting High Reliability, ICSE, p.447457, 1976. ,
DOI : 10.1007/978-3-642-82470-8_9
Mining design patterns from C++ source code, International Conference on Software Maintenance, 2003. ICSM 2003. Proceedings., p.305314, 2003. ,
DOI : 10.1109/ICSM.2003.1235436
Genesis : a project to develop an extensible database management system, OODS '86 : Proceedings on the 1986 international workshop on Object-oriented database systems, p.208, 1986. ,
Using pattern languages for object-oriented programs, OOPSLA-87 workshop on the Specication and Design for Object-Oriented Programming, 1987. ,
Componentbased E-commerce : Assessment of current practices, SIGMOD Record (ACM Special Interest Group on Management of Data), vol.27, issue.4, p.714, 1998. ,
Rational architecture for object-oriented systems, Journal of Object-Oriented Programming, vol.6, issue.5, 1993. ,
A technique for documenting the framework of an object-oriented system, [1992] Proceedings of the Second International Workshop on Object Orientation in Operating Systems, p.363389, 1993. ,
DOI : 10.1109/IWOOOS.1992.252968
A case study of framework design for horizontal reuse, Proceedings 37th International Conference on Technology of Object-Oriented Languages and Systems. TOOLS-Pacific 2000, 2000. ,
DOI : 10.1109/TOOLS.2000.891376
Advanced C++ programming styles and idioms, 1992. ,
Doing Hard Time : Developing Real-Time Systems with UML, Objects, Frameworks, and Patterns. The Addison-Wesley Object Technology Series, 1999. ,
Real-Time Design Patterns : Robust Scalable Architecture for Real-Time Systems. The Addison-Wesley Object Technology Series, BIBLIOGRAPHIE, 2002. ,
Real-Time UML, 2004. ,
DOI : 10.1007/3-540-45739-9_4
Et++swapsmanager : using object technology in the nancial engineering domain, OOPSLA '92 : conference proceedings on Objectoriented programming systems, languages, and applications, p.166177, 1992. ,
Building Application Frameworks : Object-Oriented Foundations of Framework Design, 1999. ,
Object-oriented software development based on et++ : Design patterns, class library, tools Design Patterns : Elements of Reusable Object-Oriented Software, 1992. ,
Approche du temps réel industriel, 1999. ,
Designing Concurrent, Distributed, and Real-Time Applications with UML. The Addison-Wesley Object Technology Series, 2000. ,
Monitors : an operating system structuring concept, Commun. ACM, vol.17, issue.10, p.549557, 1974. ,
A program structure for error detection and recovery, Symposium on Operating Systems, p.171187, 1974. ,
Sesag : an object-oriented application framework for realtime systems : Research articles, Softw. Pract. Exper, issue.10, p.35899921, 2005. ,
Veriable embedded real-time application framework WiP session, Proceedings of the International Symposium on Real- Time Applications and Systems (RTAS'01), p.109110, 2001. ,
Service congurator : A pattern for dynamic conguration of services, In COOTS, p.209220, 1997. ,
Frameworks = components + patterns, Communication of the ACM, vol.40, issue.10, p.3942, 1997. ,
Designing reusable classes, Journal of Object-Oriented Programming, vol.1, issue.2, p.2235, 1988. ,
Oualid Khayati. Vers des systèmes de patrons formalisés et outiés, 2001. ,
An objectoriented real-time framework and development environment, Proceeding of OOPSLA, 1995. ,
Art of Objects, The : Object-Oriented Design and Architecture. The Addison-Wesley Object Technology Series, 2000. ,
Active object : an object behavioral pattern for concurrent programming, Proc.Pattern Languages of Programs, 1995. ,
Patterns-discussion faq Recovery block design pattern : Un design pattern pour la conception des systèmes tolérants aux fautes, 3 ème Conférence Internationale de Sciences Electroniques, 2000. ,
Object-oriented frameworks -a survey of methodological issues. Master's thesis, Ronneby SWEDEN, 1996. ,
Application of patterns to real-time object-oriented software design, 2000. ,
Design patterns and real-time object-oriented modeling (poster session), Addendum to the 2000 proceedings of the conference on Object-oriented programming, systems, languages, and applications (Addendum) , OOPSLA '00, p.5556, 2000. ,
DOI : 10.1145/367845.367932
Universal service processor (usp) [En ligne] Adresse URL : http ://h71000.www7.hp.com/openvms/products, BIBLIOGRAPHIE, pp.8-2005, 2005. ,
Vers une meilleure intégration des designs patterns à la conception. Rainbow Project, 1999. ,
Building Application Frameworks : Object- Oriented Foundations of Framework Design, Chapitre Hot-Spot-Dreiven Framework Dévelopment, 1999. ,
Proactor an architectural pattern for demultiplexing and dispatching handlers for asynchronous events, 1999. ,
Quintian and Ph. Lahire. Vers une meilleure réutilisation des patrons de conception, 2001. ,
Framework-based software development in C++, 1997. ,
The Handbook of Programming Languages (HPL) : Object Oriented Programming Languages Chapitre Applying Design Patterns and Frameworks to Develop Object- Oriented Communication Software, 1997. ,
C++ Network Programming : Systematic Reuse with ACE and Frameworks, 2002. ,
Pattern-Oriented Software Architecture : Patterns for Concurrent and Networked Objects, 2000. ,
Design Patterns Application in UML, BIBLIOGRAPHIE Proceedings of ECOOP 2000, p.4462, 2000. ,
DOI : 10.1007/3-540-45102-1_3
VxWorks Programmer's Guide Implementing software-fault tolerance in c++ and open c++, Proceedings of the 1996 International Workshop on Computer-Aided Design, Test, and Evaluation for Dependability (CAD- TED '96), p.224229, 1996. ,
