Approximate dynamic programming for two-player zero-sum Markov games
This paper provides an analysis of error propagation in Approximate Dynamic Programming applied to zero-sum two-player Stochastic Games. We provide a novel and unified error propagation analysis in L p-norm of three well-known algorithms adapted to Stochastic Games (namely Approximate Value Iteration, Approximate Policy Iteration and Approximate Generalized Policy Iteratio,n). We show that we can achieve a stationary policy which is 2γ+ (1−γ) 2-optimal, where is the value function approximation error and is the approximate greedy operator error. In addition , we provide a practical algorithm (AGPI-Q) to solve infinite horizon γ-discounted two-player zero-sum Stochastic Games in a batch setting. It is an extension of the Fitted-Q algorithm (which solves Markov Decisions Processes from data) and can be non-parametric. Finally, we demonstrate experimentally the performance of AGPI-Q on a simultaneous two-player game, namely Alesia.
