Space-time sketching of character animation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2015
We present a space-time abstraction for the sketch-based design of character animation. It allows animators to draft a full coordinated motion using a single stroke called the space-time curve (STC). From the STC we compute a dynamic line of action (DLOA) that drives the motion of a 3D character through projective constraints. Our dynamic models for the line's motion are entirely geometric, require no pre-existing data, and allow full artistic control. The resulting DLOA can be refined by over-sketching strokes along the space-time curve, or by composing another DLOA on top leading to control over complex motions with few strokes. Additionally , the resulting dynamic line of action can be applied to arbitrary body parts or characters. To match a 3D character to the 2D line over time, we introduce a robust matching algorithm based on closed-form solutions, yielding a tight match while allowing squash and stretch of the character's skeleton. Our experiments show that space-time sketching has the potential of bringing animation design within the reach of beginners while saving time for skilled artists.
SpaceTimeSketching.pdf (2.46 Mo) Télécharger le fichier
space_time_sketching (1).jpeg (36.59 Ko) Télécharger le fichier
Format : Figure, Image
hal-01153763 , version 1 (22-12-2015)
Martin Guay, Rémi Ronfard, Michael Gleicher, Marie-Paule Cani. Space-time sketching of character animation. ACM Transactions on Graphics, 2015, Proceedings of ACM SIGGRAPH 2015, 34 (4), pp.Article No. 118. ⟨10.1145/2766893⟩. ⟨hal-01153763⟩
3110 Consultations
4276 Téléchargements
