RDF/XML Source Declaration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2007
When querying or reasoning on metadata from the semantic web, the source of this metadata can be of great importance. While the SPARQL query language provides a keyword to match patterns against named graphs, the RDF data model focuses on expressing triples. In many cases it is interesting to augment these RDF triples with the notion of a source for each triple (or set of triples), typically an IRI specifying their real or virtual origin. This document proposes an RDF/XML syntax extension providing an attribute to specify the source of triples in an RDF/XML representation.
XML Source Declaration.pdf (320.25 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-01154394 , version 1 (22-05-2015)
  • HAL Id : hal-01154394 , version 1
Fabien Gandon, Virginie Bottollier, Olivier Corby, Priscille Durville. RDF/XML Source Declaration. 2007. ⟨hal-01154394⟩
173 Consultations
239 Téléchargements
