SCHANK : Inside Case-Based Reasoning, 1989. ,
Applying Belief Revision to Case-Based Reasoning Computational Approaches to Analogical Reasoning : Current Trends, de Studies in Computational Intelligence, pp.133-161, 2014. ,
Révision par r-ensembles de bases de connaissances en DL-LiteR, Reconnaissance de Formes et Intelligence Artificielle, 2014. ,
Algorithm for Adapting Cases Represented in a Tractable Description Logic, Case-Based Reasoning Research and Development, Proceedings of ICCBR-2014, pp.63-78, 2014. ,
DOI : 10.1007/978-3-319-11209-1_6
An Algorithm for Adapting Cases Represented in ALC, 22th Internationational Joint Conference on Artificial Intelligence, 2011. ,
URL : https://hal.archives-ouvertes.fr/inria-00584103
Belief revision within fragments of propositional logic, Journal of Computer and System Sciences, vol.80, issue.2, pp.427-449, 2014. ,
DOI : 10.1016/j.jcss.2013.08.002
URL : https://hal.archives-ouvertes.fr/hal-01194410
From Inconsistency to Consistency: Knowledge Base Revision by Tableaux Opening, Advances in Artificial Intelligence?IBERAMIA 2010, pp.120-132, 2010. ,
DOI : 10.1007/978-3-642-16952-6_13
Adapting Propositional Cases Based on Tableaux Repairs Using Adaptation Knowledge, Luc LAMONTAGNE et Enric PLAZA, ´ editeurs : International Conference on Case-Based Reasoning, volume Case-Based Reasoning Research and Development de Lecture Notes in Computer Science, pp.390-404, 2014. ,
DOI : 10.1007/978-3-319-11209-1_28
URL : https://hal.archives-ouvertes.fr/hal-01092210
Taaable: A Case-Based System for Personalized Cooking, Stefania MONTANI et Lakhmi C. JAIN, ´ editeurs : Successful Case-based Reasoning Applications-2 de Studies in Computational Intelligence, pp.121-162, 2014. ,
DOI : 10.1007/978-3-642-38736-4_7
URL : https://hal.archives-ouvertes.fr/hal-00912767
Une approche de l'adaptation en raisonnementàraisonnement`raisonnementà partir de cas fondée sur l'optimisation sous contraintes, 2009. ,
Case Adaptation with Qualitative Algebras, Francesca ROSSI, ´ editeur : International Joint Conferences on Artificial Intelligence, pp.3002-3006, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00871703
Révision des croyances dans la clôture propositionnelle d'une algèbre qualitative, JIAF-2014 ?Huitì emes Journées de l'Intelligence Artificielle Fondamentale, JIAF Huitì emes Journées de l'Intelligence Artificielle Fondamentale, p.10, 2014. ,
Abstract, The Journal of Symbolic Logic, vol.48, issue.02, pp.510-530, 1985. ,
DOI : 10.1080/00048408412341331
Belief Revision Handbook of Knowledge Representation, pp.317-359, 2008. ,
Propositional knowledge base revision and minimal change, Artificial Intelligence, vol.52, issue.3, pp.263-294, 1991. ,
DOI : 10.1016/0004-3702(91)90069-V
Investigations into a theory of knowledge base revision : Preliminary report, AAAI, pp.475-479, 1988. ,
SCHWIND : Majority Merging : from Boolean Spaces to Affine Spaces, Proceedings of the 19th European Conference on Artificial Intelligence (ECAI-10), pp.627-632, 2010. ,
Merging Information Under Constraints: A Logical Framework, Journal of Logic and Computation, vol.12, issue.5 ,
DOI : 10.1093/logcom/12.5.773
