A. , A. Hertzmann, A. Salesin, D. H. And-seitz, and S. M. , Keyframe-based tracking for rotoscoping and animation, ACM Trans. Graph, vol.23, issue.3, pp.584-591, 2004.
A. , M. Cohen-or, D. And-levin, and D. , As-rigidas-possible shape interpolation, Proceedings of SIGGRAPH 2000, pp.157-164, 2000.
A. , P. Schuster, M. And-pettit, and T. , Dynamic planar map illustration, ACM Trans. Graph, vol.26, issue.30, pp.1-3010, 2007.
B. , P. And-gangnet, and M. , Planar maps: An interaction paradigm for graphic design, Proceedings of CHI '89, pp.313-318, 1989.
B. , W. Barla, P. And-anjyo, and K. , Compatible embedding for 2d shape animation, IEEE Trans. on Visualization and Computer Graphics, vol.15, issue.5, pp.867-879, 2009.
URL : https://hal.archives-ouvertes.fr/inria-00400828
B. , P. Lu, J. Cole, F. Finkelstein, A. And-thol-lot et al., Active strokes: Coherent line stylization for animated 3d models, Proceedings of NPAR '12, pp.37-46, 2012.
B. , P. Hertzmann, A. And-kass, and M. , Computing smooth surface contours with accurate topology, ACM Trans. Graph, vol.33, issue.19, pp.1-19, 2014.
URL : https://hal.archives-ouvertes.fr/hal-00924273
B. , C. Loeb, L. Chuang, E. And-deshpande, and H. , Turning to the masters: Motion capturing cartoons, ACM Trans. Graph, vol.21, issue.3, pp.399-407, 2002.
B. , B. Faraj, N. Paris, S. Eisemann, E. And-boubekeur et al., Spatio-temporal analysis for parameterizing animated lines, Proceedings of NPAR '11, pp.85-92, 2011.
B. , N. And-wein, and M. , Computer-generated keyframe animation, Journal of the Society of Motion Picture & Television Engineers, vol.80, issue.3, pp.149-153, 1971.
D. , B. Ronfard, R. , A. Van-de-panne, and M. , Vector graphics complexes, ACM Trans. Graph, vol.33, issue.133, pp.1-13312, 2014.
URL : https://hal.archives-ouvertes.fr/hal-00983262
D. Floriani, L. Hui, A. Panozzo, D. And-canino, and D. , A Dimension-Independent Data Structure for Simplicial Complexes, Proceedings of the 19th International Meshing Roundtable, pp.403-420, 2010.
DOI : 10.1007/978-3-642-15414-0_24
D. Juan, C. N. And-bodenheimer, and B. , Re-using traditional animation: methods for semi-automatic segmentation and inbetweening, Proceedings of SCA '06, pp.223-232, 2006.
E. , E. Paris, S. And-durand, and F. , A visibility algorithm for converting 3D meshes into editable 2D vector graphics, ACM Trans. Graph, vol.28, issue.83, pp.1-83, 2009.
F. , E. Pasko, A. And-adzhiev, and V. , Space-time and higher dimensional modeling for animation, Proceedings of Computer Animation, pp.140-145, 2000.
F. , J. Bizouarn, E. Cournarie, E. Galas, T. And-taillefer et al., TicTacToon: A paperless system for professional 2D animation, Proceedings of SIGGRAPH 95, pp.79-90, 1995.
URL : https://hal.archives-ouvertes.fr/hal-00911849
F. , F. D. Schaeken, P. Elens, K. And-reeth, and F. V. , Automatic in-betweening in computer assisted animation by exploiting 2.5D modelling techniques, Proceedings of Computer Animation, pp.192-200, 2001.
F. , H. Tai, C. And-au, O. K. , and -. , Morphing with laplacian coordinates and spatial-temporal texture, Proceedings of Pacific Graphics 2005, pp.100-102, 2005.
I. , T. Moscovich, T. And-hughes, and J. F. , Asrigid-as-possible shape manipulation, ACM Trans. Graph, vol.24, issue.3, pp.1134-1141, 2005.
K. , K. And-hart, and J. C. , Snaxels on a plane, Proceedings of NPAR '11, pp.35-42, 2011.
K. , J. J. And-doorn, and A. J. , Image processing done right, Proceedings of the 7th European Conference on Computer Vision, pp.158-172, 2002.
K. , V. And-rossignac, and J. , Space-time surface simplification and edgebreaker compression for 2D cel animations, International Journal of Shape Modeling, vol.8, issue.2, pp.119-137, 2002.
L. , D. Chen, Q. , Y. , J. Gu et al., Stroke correspondence construction using manifold learning, Computer Graphics Forum, vol.30, issue.8, pp.2194-2207, 2011.
M. , J. And-pollard, and N. , Local layering, ACM Trans. Graph, vol.28, issue.84, pp.1-84, 2009.
N. , T. Cutrell, D. Dana, J. Donald, B. Loeb et al., Accessible animation and customizable graphics via simplicial configuration modeling, Proceedings of SIG- GRAPH 2000, pp.403-410, 2000.
N. , G. Sýkora, D. Coros, S. Whited, B. Simmons et al., Temporal noise control for sketchy animation, Proceedings of NPAR '11, pp.93-98, 2011.
N. , G. Hornung, A. Sumner, R. W. Simmons, M. And et al., Topology-driven vectorization of clean line drawings, ACM Trans. Graph, vol.32, issue.1 4, pp.1-411, 2013.
O. , A. Bousseau, A. Winnemöller, H. Barla, P. Thollot et al., Diffusion curves: A vector representation for smooth-shaded images, ACM Trans. Graph, vol.27, issue.92, pp.1-928, 2008.
URL : https://hal.archives-ouvertes.fr/inria-00274768
P. , J. W. Taylor, C. D. And-willis, and P. J. , Constructing and rendering vectorised photographic images, The Journal of Virtual Reality and Broadcasting, vol.9, issue.3, 2012.
P. , S. Tavares, G. And-lopes, and H. , A stratification approach for modeling two-dimensional cell complexes, Computers & Graphics, vol.28, issue.2, pp.235-247, 2004.
R. , K. Wojtan, C. Thuerey, N. And-turk, and G. , Blending liquids, ACM Trans. Graph, vol.33, issue.137, pp.1-13710, 2014.
R. , J. And-o-'connor, and M. , SGC: A Dimensionindependent Model for Pointsets with Internal Structures and Incomplete Boundaries, 1989.
S. , T. B. Klein, P. N. And-kimia, and B. B. , On aligning curves, IEEE Trans. on Pattern Analysis and Machine Intelligence, vol.25, issue.1, pp.116-125, 2003.
S. , T. W. Gao, P. Wang, G. And-mu, and H. , 2-D shape blending: an intrinsic solution to the vertex path problem, Proceedings of SIGGRAPH 93, pp.15-18, 1993.
R. Southern, Animation manifolds for representing topological alteration, 2008.
S. , D. Dingliana, J. And, C. , and S. , Asrigid-as-possible image registration for hand-drawn cartoon animations, Proceedings of NPAR '09, pp.25-33, 2009.
S. , D. Ben-chen, M. , ?. Cadík, M. Whited et al., TexToons: practical texture mapping for hand-drawn cartoon animations, Proceedings of NPAR '11, pp.75-84, 2011.
T. , F. And-johnston, and O. , Disney Animation: The Illusion of Life, 1987.
W. , B. Noris, G. Simmons, M. Sumner, R. Gross et al., BetweenIT: An interactive tool for tight inbetweening, Computer Graphics Forum, vol.29, issue.2, pp.605-614, 2010.
Y. , J. Bian, W. Song, M. Cheng, J. And-tao et al., Graph based transductive learning for cartoon correspondence construction, Neurocomputing, vol.79, issue.0, pp.105-114, 2012.
Z. , S. Chen, T. Zhang, Y. Hu, S. And-martin et al., Vectorizing cartoon animations, IEEE Trans. on Visualization and Computer Graphics, vol.15, issue.4, pp.618-629, 2009.
