Reproducing Context-sensitive Crashes in Mobile Apps using Crowdsourced Debugging - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
While the number of mobile apps published by app stores keeps increasing, the quality of these apps greatly varies. Unfortunately, end-users continue experiencing bugs and crashes for some of the apps installed on their mobile devices. Although developers heavily test their apps before release, context-sensitive crashes might still emerge after deployment. This paper therefore introduces MoTiF, a crowdsourced approach to support developers in automatically reproducing context-sensitive crashes faced by end-users in the wild. The goal of MoTiF is to complement existing testing solutions with mechanisms to monitor and debug apps after their deployment. We demonstrate that MoTiF can effectively reproduce existing crashes in Android apps with a low overhead.
RR-8731.pdf (1.19 Mo) Télécharger le fichier
hal-01155597 , version 1 (26-05-2015)
hal-01155597 , version 2 (13-04-2016)
  • HAL Id : hal-01155597 , version 1
Maria Gomez, Romain Rouvoy, Lionel Seinturier. Reproducing Context-sensitive Crashes in Mobile Apps using Crowdsourced Debugging. [Research Report] RR-8731, Inria Lille; INRIA. 2015. ⟨hal-01155597v1⟩
Collections
INRIA-RRRT
430 Consultations
366 Téléchargements
