FA$\mu$ST: speeding up linear transforms for tractable inverse problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we propose a technique to factorize any matrix into multiple sparse factors. The resulting factorization, called Flexible Approximate MUlti-layer Sparse Transform (FAµST), yields reduced multiplication costs by the matrix and its adjoint. Such a desirable property can be used to speed up iterative algorithms commonly used to solve high dimensional linear inverse problems. The proposed approach is first motivated, introduced and related to prior art. The compromise between computational efficiency and data fidelity is then investigated, and finally the relevance of the approach is demonstrated on a problem of brain source localization using simulated magnetoencephalography (MEG) signals.
EUSIPCO_current.pdf (1.2 Mo) Télécharger le fichier
hal-01156478 , version 1 (27-05-2015)
  • HAL Id : hal-01156478 , version 1
Luc Le Magoarou, Rémi Gribonval, Alexandre Gramfort. FA$\mu$ST: speeding up linear transforms for tractable inverse problems. European Signal Processing Conference (EUSIPCO), Aug 2015, Nice, France. ⟨hal-01156478⟩
776 Consultations
315 Téléchargements
