A Subtyping for the Fisher-Honsell-Mitchell Lambda Calculus of Objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1994
Labeled types and a new relation between types are added to the lambda calculus of objects as described in [5]. This relation is a trade-off between the possibility of having a restricted form of width subtyping and the features of the delegation-based language itself. The original type inference system allows both specialization of the type of an inherited method to the type of the inheriting object and static detection of errors, such as 'message-not-understood'. The resulting calculus is an extension of the original one. Type soundness follows from the subject reduction property.
1995-csl-94.pdf (349.09 Ko) Télécharger le fichier
hal-01157171 , version 1 (27-05-2015)
Viviana Bono, Luigi Liquori. A Subtyping for the Fisher-Honsell-Mitchell Lambda Calculus of Objects. Computer Science Logic. 8th Workshop, CSL '94 Kazimierz, Poland, September 25–30, 1994 Selected Papers, Sep 1994, Kazimierz, Poland. pp.16-30, ⟨10.1007/BFb0022244⟩. ⟨hal-01157171⟩
Collections
INRIA INRIA2
129 Consultations
94 Téléchargements
