Computing Individual Discrete Logarithms Faster in GF(p$^n$) with the NFS-DL Algorithm
The Number Field Sieve (NFS) algorithm is the best known method to
compute discrete logarithms (DL) in finite fields
$\mathbf{F}_{p^n}$, with $p$ medium to large and $n \geq 1$ small. This algorithm
comprises four steps: polynomial selection, relation collection,
linear algebra and finally, individual logarithm computation. The
first step outputs two polynomials defining two number fields, and a
map from the polynomial ring over the integers modulo each of these
polynomials to $\mathbf{F}_{p^n}$.
After the relation collection and linear algebra
phases, the (virtual) logarithm of a subset of elements in each number
field is known. Given the target element in $\mathbf{F}_{p^n}$, the fourth
step computes a preimage in one number field. If one can write the
target preimage as a product of elements of known (virtual) logarithm,
then one can deduce the discrete logarithm of the target.
As recently shown by the Logjam attack, this final step can be
critical when it can be computed very quickly.
But we realized that computing an individual DL is much slower in medium-
and large-characteristic non-prime fields $\mathbf{F}_{p^n}$ with $n \geq 3$,
compared to prime fields and quadratic fields $\mathbf{F}_{p^2}$. We optimize
the first part of individual DL: the booting step, by reducing
dramatically the size of the preimage norm.
Its smoothness probability is higher, hence the running-time of the
booting step is much improved.
Our method is very efficient for small extension fields with $2 \leq
n \leq 6$ and applies to any $n > 1$, in medium and large characteristic.
