High-throughput in-situ characterization and modelling of precipitation kinetics in compositionally graded alloys - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Acta Materialia Année : 2015
The development of new engineering alloy chemistries is a time consuming and iterative process. A necessary step is characterization of the nano/microstructure to provide a link between the processing and properties of each alloy chemistry considered. One approach to accelerate the identification of optimal chemistries is to use samples containing a gradient in composition, ie. combinatorial samples, and to investigate many different chemistries at the same time. However, for engineering alloys, the final properties depend not only on chemistry but also on the path of microstructure development which necessitates characterization of microstructure evolution for each chemistry. In this contribution we demonstrate an approach that allows for the in-situ, nanoscale characterization of the precipitate structures in alloys, as a function of aging time, in combinatorial samples containing a composition gradient. The approach uses small angle x-ray scattering (SAXS) at a synchrotron beamline. The Cu-Co system is used for the proof-of-concept and the combinatorial samples prepared contain a gradient in Co from 0% to 2%. These samples are aged at temperatures between 450°C and 550°C and the precipitate structures (precipitate size, volume fraction and number density) all along the composition gradient are simultaneously monitored as a function of time. This large dataset is used to test the applicability and robustness of a conventional class model for precipitation that considers concurrent nucleation, growth and coarsening and the ability of the model to describe such a large dataset.
CuCo.pdf (1.62 Mo) Télécharger le fichier
hal-01157532 , version 1 (28-05-2015)
hal-01157532 , version 2 (27-08-2015)
F de Geuser, M.J. Styles, A Deschamps, C.R. Hutchinson. High-throughput in-situ characterization and modelling of precipitation kinetics in compositionally graded alloys. Acta Materialia, 2015, ⟨10.1016/j.actamat.2015.08.061⟩. ⟨hal-01157532v2⟩
204 Consultations
221 Téléchargements
