A classification method for binary predictors combining similarity measures and mixture models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Dependence Modeling Année : 2015
In this paper, a new supervised classification method dedicated to binary predictors is proposed. Its originality is to combine a model-based classification rule with similarity measures thanks to the introduction of new family of exponential kernels. Some links are established between existing similarity measures when applied to binary predictors. A new family of measures is also introduced to unify some of the existing literature. The performance of the new classification method is illustrated on two real datasets (verbal autopsy data and handwritten digit data) using 76 similarity measures.
review_article_statistical2.pdf (552.57 Ko) Télécharger le fichier
hal-01158043 , version 1 (29-05-2015)
hal-01158043 , version 2 (11-06-2015)
hal-01158043 , version 3 (25-09-2015)
hal-01158043 , version 4 (20-11-2015)
hal-01158043 , version 5 (22-04-2016)
  • HAL Id : hal-01158043 , version 4
Seydou Nourou Sylla, Stéphane Girard, Abdou Ka Diongue, Aldiouma Diallo, Cheikh Sokhna. A classification method for binary predictors combining similarity measures and mixture models. Dependence Modeling, 2015, 3, pp.240--255. ⟨hal-01158043v4⟩
465 Consultations
579 Téléchargements
