Super-resolution reconstruction of hyperspectral images, IEEE Transactions on Image Processing, vol.14, issue.11, pp.1860-1875, 2005. ,
DOI : 10.1109/TIP.2005.854479
Proximal Alternating Minimization and Projection Methods for Nonconvex Problems: An Approach Based on the Kurdyka-??ojasiewicz Inequality, Mathematics of Operations Research, vol.35, issue.2, pp.438-457, 2010. ,
DOI : 10.1287/moor.1100.0449
Convergence of descent methods for semi-algebraic and tame problems: proximal algorithms, forward???backward splitting, and regularized Gauss???Seidel methods, Mathematical Programming, vol.31, issue.1, pp.91-129, 2013. ,
DOI : 10.1007/s10107-011-0484-9
URL : https://hal.archives-ouvertes.fr/inria-00636457
Super-resolution optical flow, 1999. ,
A Database and Evaluation Methodology for Optical Flow, International Journal of Computer Vision, vol.27, issue.3, pp.1-31, 2011. ,
DOI : 10.1007/s11263-010-0390-2
Distributed Optimization and Statistical Learning via the Alternating Direction Method of Multipliers, Foundations and Trends?? in Machine Learning, vol.3, issue.1, pp.1-122, 2011. ,
DOI : 10.1561/2200000016
Fast filter transform for image processing, Computer Graphics and Image Processing, vol.16, issue.1, pp.20-51, 1981. ,
DOI : 10.1016/0146-664X(81)90092-7
A Naturalistic Open Source Movie for Optical Flow Evaluation, European Conf. on Computer Vision, Part IV, pp.611-625, 2012. ,
DOI : 10.1007/978-3-642-33783-3_44
Fast Discrete Curvelet Transforms, Multiscale Modeling & Simulation, vol.5, issue.3, pp.861-899, 2006. ,
DOI : 10.1137/05064182X
New tight frames of curvelets and optimal representations of objects with piecewise C 2 singularities, Comm. on Pure and Appl. Math. pp, pp.219-266, 2002. ,
Super-resolution from multiple views using learnt image models, Proceedings of the 2001 IEEE Computer Society Conference on Computer Vision and Pattern Recognition. CVPR 2001, pp.627-634, 2001. ,
DOI : 10.1109/CVPR.2001.991022
On the Design of the LMS Algorithm for Robustness to Outliers in Super-Resolution Video Reconstruction, 2006 International Conference on Image Processing, pp.1737-1740, 2006. ,
DOI : 10.1109/ICIP.2006.312717
Statistical Analysis of the LMS Algorithm Applied to Super-Resolution Image Reconstruction, IEEE Transactions on Signal Processing, vol.55, issue.5, pp.2084-2095, 2007. ,
DOI : 10.1109/TSP.2007.892704
Registration Errors: Are They Always Bad for Super-Resolution?, IEEE Transactions on Signal Processing, vol.57, issue.10, pp.3815-3826, 2009. ,
DOI : 10.1109/TSP.2009.2023402
On an Iterative Method for Super-resolution, Optica Acta: International Journal of Optics, vol.44, issue.8, pp.691-695, 1975. ,
DOI : 10.1364/JOSA.64.001498
Nonlocally Centralized Sparse Representation for Image Restoration, IEEE Transactions on Image Processing, vol.22, issue.4, pp.1620-1630, 2013. ,
DOI : 10.1109/TIP.2012.2235847
On the Douglas???Rachford splitting method and the proximal point algorithm for maximal monotone operators, Mathematical Programming, vol.29, issue.1, pp.293-318, 1992. ,
DOI : 10.1007/BF01581204
Super-resolution reconstruction of image sequences. Pattern Analysis and Machine Intelligence, IEEE Transactions on, vol.21, issue.9, pp.817-834, 1999. ,
Superresolution restoration of an image sequence: adaptive filtering approach, IEEE Transactions on Image Processing, vol.8, issue.3, pp.387-395, 1999. ,
DOI : 10.1109/83.748893
Super-resolution restoration of continuous image sequence using the LMS algorithm, Eighteenth Convention of Electrical and Electronics Engineers in Israel, 1995. ,
DOI : 10.1109/EEIS.1995.513799
Video-to-Video Dynamic Super-Resolution for Grayscale and Color Sequences, EURASIP Journal on Advances in Signal Processing, vol.68, issue.3, p.61859, 2006. ,
DOI : 10.1155/ASP/2006/61859
Fast and Robust Multiframe Super Resolution, IEEE Transactions on Image Processing, vol.13, issue.10, pp.1327-1344, 2004. ,
DOI : 10.1109/TIP.2004.834669
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.15.2875
A mathematical introduction to compressive sensing. Applied and Numerical Harmonic Analysis, Birkhaüser, 2013. ,
Optical flow based super-resolution: A probabilistic approach, Computer Vision and Image Understanding, vol.1061, pp.106-115, 2007. ,
Super-resolution through Error Energy Reduction, Optica Acta: International Journal of Optics, vol.19, issue.9, pp.709-720, 1974. ,
DOI : 10.1080/713818946
A Fast Image Super-Resolution Algorithm Using an Adaptive Wiener Filter, IEEE Transactions on Image Processing, vol.16, issue.12, pp.2953-2964, 2007. ,
DOI : 10.1109/TIP.2007.909416
High-resolution image reconstruction from a sequence of rotated and translated frames and its application to an infrared imaging system, Optical Engineering, vol.37, issue.1, pp.247-260, 1998. ,
Beta Process Joint Dictionary Learning for Coupled Feature Spaces with Application to Single Image Super-Resolution, 2013 IEEE Conference on Computer Vision and Pattern Recognition, pp.345-352, 2013. ,
DOI : 10.1109/CVPR.2013.51
Video Super-Resolution Using Simultaneous Motion and Intensity Calculations, IEEE Transactions on Image Processing, vol.20, issue.7, pp.1870-1884, 2011. ,
DOI : 10.1109/TIP.2011.2106793
Analyses multirésolutions non orthogonales, commutation entre projecteurs et dérivation et ondelettes vecteursàvecteurs`vecteursà divergence nulle, Revista Matematica Iberoamericana, vol.8, pp.221-237, 1992. ,
On bayesian adaptive video super resolution. Pattern Analysis and Machine Intelligence, IEEE Transactions on, vol.36, issue.2, pp.346-360, 2014. ,
A Wavelet Tour of Signal Processing: The Sparse Way, 2008. ,
Lessons in Estimation Theory for Signal Processing Communications and Control, 1995. ,
Video Super Resolution Using Duality Based TV-L 1 Optical Flow, In: Pattern Recognition Lecture Notes in Computer Science, vol.18, pp.432-441, 2009. ,
DOI : 10.1137/1.9781611970944
Super-resolution: a comprehensive survey, Machine Vision and Applications, vol.21, issue.1, pp.1423-1468, 2014. ,
DOI : 10.1007/s00138-014-0623-4
Numerical Optimization. Springer Series in Operations Research, 1999. ,
Proximal Algorithms, Foundations and Trends?? in Optimization, vol.1, issue.3, pp.127-239, 2014. ,
DOI : 10.1561/2400000003
Superresolution video reconstruction with arbitrary sampling lattices and nonzero aperture time, IEEE Transactions on Image Processing, vol.6, issue.8, pp.1064-1076, 1997. ,
DOI : 10.1109/83.605404
Improving image resolution using subpixel motion, Pattern Recognition Letters, vol.5, issue.3, pp.223-226, 1987. ,
DOI : 10.1016/0167-8655(87)90067-5
A Statistical Prediction Model Based on Sparse Representations for Single Image Super-Resolution, IEEE Transactions on Image Processing, vol.23, issue.6, pp.2569-2582, 2014. ,
DOI : 10.1109/TIP.2014.2305844
Super Resolution Image Reconstruction Through Bregman Iteration Using Morphologic Regularization, IEEE Transactions on Image Processing, vol.21, issue.9, pp.4029-4039, 2012. ,
DOI : 10.1109/TIP.2012.2201492
Robust Image Reconstruction from Multiview Measurements, SIAM Journal on Imaging Sciences, vol.7, issue.1, pp.128-156, 2014. ,
DOI : 10.1137/120902586
URL : http://arxiv.org/abs/1212.3268
Super-resolution in diffraction tomography, Inverse Problems, vol.8, issue.1, p.149, 1992. ,
DOI : 10.1088/0266-5611/8/1/010
Extraction of high-resolution frames from video sequences, IEEE Transactions on Image Processing, vol.5, issue.6, pp.996-1011, 1996. ,
DOI : 10.1109/83.503915
Locally adaptive kernel regression for space-time super-resolution. In: Super-Resolution Imaging, Digital Imaging and Computer Vision, pp.63-69, 2010. ,
Super-Resolution Without Explicit Subpixel Motion Estimation, IEEE Transactions on Image Processing, vol.18, issue.9, pp.1958-1975, 2009. ,
DOI : 10.1109/TIP.2009.2023703
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.141.510
Reconstruction of a high resolution image from registration and restoration of low resolution images, Proceedings of 1st International Conference on Image Processing, pp.553-557, 1994. ,
DOI : 10.1109/ICIP.1994.413745
Multiframe image restoration and registration, Advances in Computer Vision and Image Processing, pp.317-339, 1984. ,
Graphics gems. chap. Filters for Common Resampling Tasks, pp.147-165, 1990. ,
A Convex Approach for Variational Super-Resolution, Pattern Recognition Lecture Notes in Computer Science, vol.6376, pp.313-322, 2010. ,
DOI : 10.1007/978-3-642-15986-2_32
Fast B-spline transforms for continuous image representation and interpolation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.3, pp.277-285, 1991. ,
DOI : 10.1109/34.75515
Super-resolution video restoration with model uncertainties In: Image Processing, Proceedings. 2002 International Conference on, pp.853-856, 2002. ,
A theoretical framework for convex regularizers in pde-based computation of image motion, Int. J. Computer Vision pp, pp.245-264, 2004. ,
Motion detail preserving optical flow estimation, 2010 IEEE Computer Society Conference on Computer Vision and Pattern Recognition, pp.1744-1757, 2012. ,
DOI : 10.1109/CVPR.2010.5539820
New results on performance analysis of super-resolution image reconstruction, 2009 16th IEEE International Conference on Image Processing (ICIP), pp.1517-1520, 2009. ,
DOI : 10.1109/ICIP.2009.5413624
Image Super-Resolution Via Sparse Representation, IEEE Transactions on Image Processing, vol.19, issue.11, pp.2861-2873, 2010. ,
DOI : 10.1109/TIP.2010.2050625
Multiframe super-resolution employing a spatially weighted total variation model. Circuits and Systems for Video Technology, IEEE Transactions on, vol.22, issue.3, pp.379-392, 2012. ,
A Duality Based Approach for Realtime TV-L 1 Optical Flow, Ann. Symp. German Association Patt. Recogn, pp.214-223, 2007. ,
DOI : 10.1007/978-3-540-74936-3_22
Is Super-Resolution with Optical Flow Feasible?, Lecture Notes in Computer Science, vol.2350, issue.40, pp.599-613, 2002. ,
DOI : 10.1007/3-540-47969-4_40
Motion field estimated from low-resolved images of data set #1 at initial time. Top: estimates for state-of-the-art algorithms [57] (left) and, p.61 ,
Reconstruction of three super-resolved images xt (3-rd row), optic-flow fields dt (1-st row) and warping errors t (2-nd row) for data set #3 corresponding to t = 3 (left) t = 5 (middle) and t = 7 (right) True images (4-th row) and associated PSNR (computed without quantification of the estimates and including the image borders) are displayed below ,
