Conference papers
Uncertainty propagation for noise robust speaker recognition: the case of NIST-SRE
Dayana Ribas 1 Emmanuel Vincent 2 José Ramon Calvo 1
2 MULTISPEECH - Speech Modeling for Facilitating Oral-Based Communication
Inria Nancy - Grand Est, LORIA - NLPKD - Department of Natural Language Processing & Knowledge Discovery
Abstract : Uncertainty propagation is an established approach to handle noisy and reverberant conditions in automatic speech recognition (ASR), but it has little been studied for speaker recognition so far. Yu et al. recently proposed to propagate uncertainty to the Baum-Welch (BW) statistics without changing the posterior probability of each mixture component. They obtained good results on a small dataset (YOHO) but little improvement on the NIST-SRE dataset, despite the use of oracle uncertainty estimates. In this paper, we propose to modify the computation of the posterior probability of each mixture component in order to obtain unbiased BW statistics. We show that our approach improves the accuracy of BW statistics on the Wall Street Journal (WSJ) corpus, but yields little or no improvement on NIST-SRE again. We provide a theoretical explanation for this that opens the way for more efficient exploitation of uncertainty on NIST-SRE and other large datasets in the future.
Document type :
Conference papers
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/hal-01158775
Contributor : Emmanuel Vincent Connect in order to contact the contributor
Submitted on : Wednesday, August 5, 2015 - 5:15:09 PM
Last modification on : Saturday, October 16, 2021 - 11:26:09 AM
Long-term archiving on: : Wednesday, April 26, 2017 - 9:50:55 AM
File
UPivector_2015.pdf
Identifiers
  • HAL Id : hal-01158775, version 3
Citation
Dayana Ribas, Emmanuel Vincent, José Ramon Calvo. Uncertainty propagation for noise robust speaker recognition: the case of NIST-SRE. Interspeech 2015, Sep 2015, Dresden, Germany. pp.5. ⟨hal-01158775v3⟩
Share
Metrics
Les métriques sont temporairement indisponibles
