Learning to track for spatio-temporal action localization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose an effective approach for action localization, both in the spatial and temporal domains, in realistic videos. The approach starts from detecting proposals at frame-level, and proceeds to scoring them using a combination of static and motion state-of-the-art features extracted from CNNs. We then track a selection of proposals throughout the video, using a tracking-by-detection approach that leverages a combination of instance-level and class-specific learned detectors. The tracks are scored using a spatio-temporal motion histogram (STMH), a novel descriptor at the track level, in combination with the CNN features. Finally, we perform temporal localization of the action using a sliding-window approach. We present experimental results on the UCF-Sports and J-HMDB action localization datasets, where our approach outperforms the state of the art with a margin of 15% and 7% respectively in mAP. Furthermore, we present the first experimental results on the challenging UCF-101 localization dataset with 24 classes, where we also obtain a promising performance.
WeinzaepfelICCV2015.pdf (742.29 Ko) Télécharger le fichier
WeinzaepfelICCV2015_video.mp4 (11.3 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
hal-01159941 , version 1 (05-06-2015)
hal-01159941 , version 2 (01-10-2015)
Philippe Weinzaepfel, Zaid Harchaoui, Cordelia Schmid. Learning to track for spatio-temporal action localization. ICCV - IEEE International Conference on Computer Vision, Dec 2015, Santiago, Chile. pp.3164-3172, ⟨10.1109/ICCV.2015.362⟩. ⟨hal-01159941v2⟩
1691 Consultations
2978 Téléchargements
