On Homogeneous Evolution Equation in a Banach Space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A geometric homogeneity of evolution equation in a Banach space is introduced. Scalability property of solutions of homogeneous evolution equations is proven. Some qualitative characteristics of stability of trivial solution are also provided. In particular, finite-time stability of homogeneous evolution equations is studied. Theoretical results are supported by examples from mathematical physics.
Automatique
HomEE_ecc.pdf (261.02 Ko) Télécharger le fichier
hal-01160068 , version 1 (04-06-2015)
  • HAL Id : hal-01160068 , version 1
Andrey Polyakov, Denis Efimov, E Fridman, Wilfrid Perruquetti. On Homogeneous Evolution Equation in a Banach Space. European Control Conference 2015, Jul 2015, Linz, Austria. ⟨hal-01160068⟩
160 Consultations
364 Téléchargements
