Multi-ML: Programming Multi-BSP Algorithms in ML - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Parallel Programming Année : 2015
The multi-bsp model is an extension of the well known bsp bridging model. It brings a tree based view of nested components to represent hierarchical architectures. In the past, we designed bsml for programming bsp algorithms in ml. We now propose the multi-ml language as an extension of bsml for programming multi-bsp algorithms in ml.
article.pdf (462.57 Ko) Télécharger le fichier
hal-01160164 , version 1 (04-06-2015)
hal-01160164 , version 2 (25-06-2015)
hal-01160164 , version 3 (03-02-2016)
  • HAL Id : hal-01160164 , version 1
Victor Allombert, Frédéric Gava, Julien Tesson. Multi-ML: Programming Multi-BSP Algorithms in ML. International Journal of Parallel Programming, 2015, pp.20. ⟨hal-01160164v1⟩
304 Consultations
384 Téléchargements
