Immediate from Lemma 6.2 and Theorem 2.3 via the same type of manipulation that proves Theorem 1 ,
Invariance We now use Lemma 6.3 to show that a regular language is definable in Arb-invariant FO(Succ) iff it is definable in FO(Succ, lm). The " only if " direction is straightforward as any predicate of the form lm can be expressed in Arb-invariant FO(Succ) (actually only addition is needed) ,
e i vf i and f i z to their corresponding substring in the other string. Hence by Theorem 5.1 we have xe 2i uf 2i ye 2i vf 2i z ? L iff xe 2i vf 2i ye 2i uf 2i z ? L. But again, as e and f are idempotents, this implies xeuf yevf z ? L iff xeuf yevf z ? L. Therefore L is closed under swaps. The pumping argument for closure under transfers is identical. By Lemma 6.3 there are constants c and n 0 such that L is closed under (log n) c -transfers for strings of length bigger than n 0 . Consider x, u, y, v, z as in the hypothesis for closure under transfers. As u ? and v ? are idempotents we have for all i ? N, xu ?·i uyv ?·i z ? L iff xu ? uyv ? z ? L. Take i large enough so that i · ? ? (log |xu ?·i uyv ?·i z|) c ? (log n 0 ) c . Hence we can apply closure under (log n) c -transfers and by Lemma 6, xe 2i vf 2i ye 2i uf 2i z via the bijection sending respectively ,
Foundations of Databases, 1995. ,
???11-Formulae on finite structures, Annals of Pure and Applied Logic, vol.24, issue.1, pp.1-48, 1983. ,
DOI : 10.1016/0168-0072(83)90038-6
First-order definability on finite structures, Annals of Pure and Applied Logic, vol.45, issue.3, pp.211-225, 1989. ,
DOI : 10.1016/0168-0072(89)90036-5
On a method for obtaining lower bounds for the complexity of individual monotone functions, Soviet Math. Dokl, vol.31, issue.3, pp.530-534, 1985. ,
Locality of Queries Definable in Invariant First-Order Logic with Arbitrary Built-in Predicates, Proc. Intl. Colloq. on Automata, Languages and Programming (ICALP), pp.368-379, 2011. ,
DOI : 10.1007/10703163_10
Factors of words, Proc. Intl, pp.63-79, 1989. ,
Regular tree languages definable in FO and FO mod, ACM Transactions on Computational Logic, vol.11, issue.1, 2009. ,
Towards a Characterization of Order-Invariant Queries over Tame Structures, Journal of Symbolic Logic, vol.74, issue.1, pp.168-186, 2009. ,
DOI : 10.1007/11538363_20
Orna Grumberg, and Doron A. Peled. Model Checking, 1999. ,
Counting results in weak formalisms, Circuits, Logic, and Games, number 06451 in Dagstuhl Seminar Proc. Internationales Begegnungs-und Forschungszentrum für Informatik (IBFI), Schloss Dagstuhl, 2007. ,
Finite model theory, 1999. ,
Parity, circuits, and the polynomial-time hierarchy, Mathematical Systems Theory, vol.3, issue.1, pp.13-27, 1984. ,
DOI : 10.1007/BF01744431
On monadic NP vs. monadic co-NP. Information and Computation, pp.78-92, 1995. ,
On Local and Non-Local Properties, Proc. Herbrand Symposium, Logic Colloquium, pp.105-135, 1981. ,
DOI : 10.1016/S0049-237X(08)71879-2
Methods for algorithmic meta theorems, Model Theoretic Methods in Finite Combinatorics, 2011. ,
DOI : 10.1090/conm/558/11051
Fixed-Point Definability and Polynomial Time, Proc. Conf. for Computer Science Logic (CSL), pp.20-23, 2009. ,
DOI : 10.1016/S0304-3975(98)00314-4
Locality of order-invariant first-order formulas, ACM Transactions on Computational Logic, vol.1, issue.1, pp.112-130, 2000. ,
DOI : 10.1145/343369.343386
MODEL-THEORETIC METHODS IN THE STUDY OF ELEMENTARY LOGIC ,
DOI : 10.1016/B978-0-7204-2233-7.50020-4
The Theory of Models, pp.132-145, 1965. ,
Computational limitations for small-depth circuits, 1986. ,
Abstract, The Journal of Symbolic Logic, vol.1450, issue.04, pp.1751-1773, 1999. ,
DOI : 10.1016/0168-0072(94)00025-X
Relational queries computable in polynomial time, Information and Control, vol.68, issue.1-3, pp.86-104, 1986. ,
DOI : 10.1016/S0019-9958(86)80029-8
Languages that Capture Complexity Classes, SIAM Journal on Computing, vol.16, issue.4, pp.760-778, 1987. ,
DOI : 10.1137/0216051
Descriptive Complexity, 1999. ,
DOI : 10.1007/978-1-4612-0539-5
Expressive power of SQL, Theoretical Computer Science, vol.296, issue.3, pp.379-404, 2003. ,
DOI : 10.1016/S0304-3975(02)00736-3
Elements of Finite Model Theory, 2004. ,
DOI : 10.1007/978-3-662-07003-1
Constant depth circuits, Fourier transform, and learnability, Journal of the ACM, vol.40, issue.3, pp.607-620, 1993. ,
DOI : 10.1145/174130.174138
Counting and Locality over Finite Structures A Survey, Generalized Quantifiers and Computation, 9th European Summer School in Logic, Language, and Information (ESSLLI'97, pp.18-50, 2000. ,
DOI : 10.1007/3-540-46583-9_2
Invariant definability, Proc. 5th Kurt Gödel Colloquium (KGC'97, pp.186-202, 1997. ,
DOI : 10.1007/3-540-63385-5_43
Invariant Definability and P/poly, Proc. Conf. for Computer Science Logic (CSL), pp.142-158, 1998. ,
Abstract, The Journal of Symbolic Logic, vol.2, issue.04, pp.1749-1757, 2000. ,
DOI : 10.1006/inco.1996.0070
Lower bounds on the monotone complexity of some boolean functions, Soviet Math. Dokl, vol.31, pp.354-357, 1985. ,
Abstract, The Journal of Symbolic Logic, vol.1, issue.02, pp.601-618, 2007. ,
DOI : 10.2178/jsl/1185803625
On the constant-depth complexity of k-clique, Proceedings of the fourtieth annual ACM symposium on Theory of computing, STOC 08, pp.721-730, 2008. ,
DOI : 10.1145/1374376.1374480
Average-Case Complexity of Detecting Cliques, 2010. ,
Arithmetic, first-order logic, and counting quantifiers, ACM Transactions on Computational Logic, vol.6, issue.3, pp.634-671, 2005. ,
DOI : 10.1145/1071596.1071602
Addition-Invariant FO and Regularity, 2010 25th Annual IEEE Symposium on Logic in Computer Science, pp.273-282, 2010. ,
DOI : 10.1109/LICS.2010.16
Database Theory, Algorithms and Theory of Computation Handbook, 2009. ,
DOI : 10.1201/9781584888215-c19
Graph congruences and wreath products, Journal of Pure and Applied Algebra, vol.36, pp.205-215, 1985. ,
DOI : 10.1016/0022-4049(85)90071-4
The complexity of relational query languages, Proc. Symp. on the Theory of Computing (STOC), pp.137-146, 1982. ,
Separating the polynomial-time hierarchy by oracles (Preliminary Version), Proc. Symp. on Foundations of Computer Science (FOCS), pp.1-10, 1985. ,
