A combined finite volume - finite element scheme for a dispersive shallow water system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We propose a variational framework for the resolution of a non-hydrostatic Saint-Venant type model with bottom topography. This model is a shallow water type approximation of the incompressible Euler system with free surface and slightly differs from the Green-Nagdhi model, see [13] for more details about the model derivation. The numerical approximation relies on a prediction-correction type scheme initially introduced by Chorin-Temam [17] to treat the incompressibility in the Navier-Stokes equations. The hyperbolic part of the system is approximated using a kinetic finite volume solver and the correction step implies to solve a mixed problem where the velocity and the pressure are defined in compatible finite element spaces. The resolution of the incompressibility constraint leads to an elliptic problem involving the non-hydrostatic part of the pressure. This step uses a variational formulation of a shallow water version of the incompressibility condition. Several numerical experiments are performed to confirm the relevance of our approach.
formVarA.pdf (695.29 Ko) Télécharger le fichier
hal-01160718 , version 1 (08-06-2015)
hal-01160718 , version 2 (10-06-2015)
hal-01160718 , version 3 (30-06-2015)
N. Assiouene, Marie-Odile Bristeau, Edwige Godlewski, Jacques Sainte-Marie. A combined finite volume - finite element scheme for a dispersive shallow water system. 2015. ⟨hal-01160718v1⟩
507 Consultations
340 Téléchargements
