Intrinsic Finite Element Methods for the Computation of Fluxes for Poisson's Equation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2015
In this paper we consider an intrinsic approach for the direct computation of the fluxes for problems in potential theory. We develop a general method for the derivation of intrinsic conforming and non-conforming finite element spaces and appropriate lifting operators for the evaluation of the right-hand side from abstract theoretical principles related to the second Strang Lemma. This intrinsic finite element method is analyzed and convergence with optimal order is proved.
CCSS-HAL (1).pdf (2.56 Mo) Télécharger le fichier
hal-01160896 , version 1 (08-06-2015)
Philippe G. Ciarlet, Patrick Ciarlet, Stefan Sauter, C Simian. Intrinsic Finite Element Methods for the Computation of Fluxes for Poisson's Equation. Numerische Mathematik, 2015, pp.30. ⟨10.1007/s00211-015-0730-9⟩. ⟨hal-01160896⟩
198 Consultations
215 Téléchargements
