Learning with Submodular Functions: A Convex Optimization Perspective, Foundations and Trends?? in Machine Learning, vol.6, issue.2-3, 2013. ,
DOI : 10.1561/2200000039
URL : https://hal.archives-ouvertes.fr/hal-00645271
Dykstra???s Alternating Projection Algorithm for Two Sets, Journal of Approximation Theory, vol.79, issue.3, pp.418-443, 1994. ,
DOI : 10.1006/jath.1994.1136
The method of cyclic projections for closed convex sets in Hilbert space, Contemporary Mathematics, vol.204, pp.1-38, 1997. ,
DOI : 10.1090/conm/204/02620
Finding best approximation pairs relative to two closed convex sets in Hilbert spaces, Journal of Approximation Theory, vol.127, issue.2, pp.178-192, 2004. ,
DOI : 10.1016/j.jat.2004.02.006
URL : https://hal.archives-ouvertes.fr/hal-00017939
Nonlinear programming, Athena Scientific, 1999. ,
Active set algorithms for isotonic regression; A unifying framework, Mathematical Programming, pp.425-439, 1990. ,
DOI : 10.1007/BF01580873
An experimental comparison of min-cut/max- flow algorithms for energy minimization in vision, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.9, pp.1124-1137, 2004. ,
DOI : 10.1109/TPAMI.2004.60
Fast approximate energy minimization via graph cuts, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.23, issue.11, pp.1222-1239, 2001. ,
DOI : 10.1109/34.969114
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.112.6806
Provable submodular minimization using Wolfe's algorithm, Advances in Neural Information Processing Systems, 2014. ,
On Total Variation Minimization and Surface Evolution Using Parametric Maximum Flows, International Journal of Computer Vision, vol.40, issue.9, pp.288-307, 2009. ,
DOI : 10.1007/s11263-009-0238-9
A remark on accelerated block coordinate descent for computing the proximity operators of a sum of convex functions, SMAI Journal of Computational Mathematics, vol.1 ,
DOI : 10.5802/smai-jcm.3
URL : https://hal.archives-ouvertes.fr/hal-01099182
Lexicographically Optimal Base of a Polymatroid with Respect to a Weight Vector, Mathematics of Operations Research, vol.5, issue.2, pp.186-196, 1980. ,
DOI : 10.1287/moor.5.2.186
Submodular Functions and Optimization, 2005. ,
A cyclic projection algorithm via duality, Metrika, vol.68, issue.1, pp.29-54, 1989. ,
DOI : 10.1007/BF02614077
Parametric Maximum Flow Algorithms for Fast Total Variation Minimization, SIAM Journal on Scientific Computing, vol.31, issue.5, pp.3712-3743, 2009. ,
DOI : 10.1137/070706318
Two algorithms for maximizing a separable concave function over a polymatroid feasible region, European Journal of Operational Research, vol.54, issue.2, pp.227-236, 1991. ,
DOI : 10.1016/0377-2217(91)90300-K
Reflection methods for user-friendly submodular optimization, Advances in Neural Information Processing Systems, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00905258
Minimizing a sum of submodular functions, Discrete Applied Mathematics, vol.160, issue.15, p.2012 ,
DOI : 10.1016/j.dam.2012.05.025
MRF Energy Minimization and Beyond via Dual Decomposition, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.33, issue.3, pp.531-552, 2011. ,
DOI : 10.1109/TPAMI.2010.108
URL : https://hal.archives-ouvertes.fr/hal-00856311
Submodularity and its applications in optimized information gathering, ACM Transactions on Intelligent Systems and Technology, vol.2, issue.4, 2011. ,
DOI : 10.1145/1989734.1989736
Convex optimization for parallel energy minimization ,
URL : https://hal.archives-ouvertes.fr/hal-01123492
Graph Cut Based Inference with Co-occurrence Statistics, Proceedings of the 11th European Conference on Computer Vision, 2010. ,
DOI : 10.1007/978-3-642-15555-0_18
Cut Pursuit: fast algorithms to learn piecewise constant functions, Proceedings of Artificial Intelligence and Statistics, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01306786
A class of submodular functions for document summarization, Proceedings of NAACL/HLT, 2011. ,
Submodular functions and convexity Mathematical programming: the state of the art, pp.235-257, 1982. ,
Numerical optimization. Springer Series in Operations Research and Financial Engineering, 2006. ,
Estimation of the convergence rate of Dykstra???s cyclic projections algorithm in polyhedral case, Acta Mathematicae Applicatae Sinica, vol.15, issue.2, pp.217-220, 2000. ,
DOI : 10.1007/BF02677683
Efficient minimization of decomposable submodular functions, Advances in Neural Information Processing Systems, 2010. ,
Balancing Applied to Maximum Network Flow Problems, European Symp. on Algorithms (ESA), pp.612-623, 2006. ,
DOI : 10.1007/11841036_55
Lx = B -Laplacian Solvers and Their Algorithmic Applications, 2013. ,
