On a class of error correcting binary group codes, Information and Control, vol.3, issue.1, pp.68-79, 1960. ,
DOI : 10.1016/S0019-9958(60)90287-4
Codes correcteurs d'Erreurs, Chiffres (Paris), vol.2, pp.147-156, 1959. ,
Decoding beyond the BCH bound (Corresp.), IEEE Transactions on Information Theory, vol.18, issue.3, pp.441-444, 1972. ,
DOI : 10.1109/TIT.1972.1054824
Generalizations of the BCH bound, Information and Control, vol.20, issue.5, pp.489-498, 1972. ,
DOI : 10.1016/S0019-9958(72)90887-X
Semisimple cyclic and Abelian codes. II, Cybernetics, vol.3, issue.3, pp.17-23, 1967. ,
DOI : 10.1007/BF01119999
Polynomial weights and code constructions, IEEE Transactions on Information Theory, vol.19, issue.1, pp.101-110, 1973. ,
DOI : 10.1109/TIT.1973.1054936
URL : http://orbit.dtu.dk/ws/files/4637283/J%C3%B8rn.pdf
Hasse Derivatives and Repeated-Root Cyclic Codes, IEEE International Symposium on Information Theory (ISIT), p.39, 1986. ,
On Repeated-Single-Root Constacyclic Codes, " in Communications and Cryptography, ser. The Springer International Series in Engineering and Computer Science, pp.93-99, 1994. ,
On the Minimum Distance of Long Cyclic Codes and Cyclic Redundancy Check Codes, 1989. ,
On repeated-root cyclic codes, IEEE Transactions on Information Theory, vol.37, issue.2, pp.337-342, 1991. ,
DOI : 10.1109/18.75249
Checking matrix of a cyclic code generated by multiple roots, Journal of Soviet Mathematics, vol.43, issue.3, pp.2492-2495, 1988. ,
DOI : 10.1007/BF01095658
Repeated-root cyclic codes, IEEE Transactions on Information Theory, vol.37, issue.2, pp.343-345, 1991. ,
DOI : 10.1109/18.75250
On generalizations of repeated-root cyclic codes, IEEE Transactions on Information Theory, vol.42, issue.2, pp.641-649, 1996. ,
DOI : 10.1109/18.485736
Weight distributions of cyclic self-dual codes, IEEE Transactions on Information Theory, vol.49, issue.6, pp.1582-1591, 2003. ,
DOI : 10.1109/TIT.2003.811921
On the Algebraic Structure of Quasi-cyclic Codes IV: Repeated Roots, Designs, Codes and Cryptography, vol.51, issue.3, pp.337-361, 2006. ,
DOI : 10.1007/s10623-005-1431-7
Repeated-Root Constacyclic Codes of Length 2p s , " Finite Fields Th, App, vol.18, issue.1, pp.133-143, 2012. ,
A new bound on the minimum distance of cyclic codes using small-minimum-distance cyclic codes, Designs, Codes and Cryptography, vol.8, issue.1, pp.229-246, 2014. ,
DOI : 10.1007/s10623-012-9721-3
URL : https://hal.archives-ouvertes.fr/hal-00710290
Decoding Cyclic Codes up to a New Bound on the Minimum Distance, IEEE Transactions on Information Theory, vol.58, issue.6, pp.3951-3960, 2012. ,
DOI : 10.1109/TIT.2012.2185924
URL : https://hal.archives-ouvertes.fr/hal-00975947
Cyclic product codes, IEEE Transactions on Information Theory, vol.11, issue.3, pp.433-439, 1965. ,
DOI : 10.1109/TIT.1965.1053802
Further results on cyclic product codes, IEEE Transactions on Information Theory, vol.16, issue.4, pp.452-459, 1970. ,
DOI : 10.1109/TIT.1970.1054491
A generalized Euclidean algorithm for multisequence shift-register synthesis, IEEE Transactions on Information Theory, vol.35, issue.3, pp.584-594, 1989. ,
DOI : 10.1109/18.30981
Theorie der höheren Differentiale in einem algebraischen Funktionenkörper mit vollkommenem Konstantenkörper bei beliebiger Charakteristik, Journal für die Reine und Angewandte Mathematik, issue.175, pp.50-54, 1936. ,
Decoding for iterative Reed-Solomon coding schemes, IEEE Transactions on Magnetics, vol.33, issue.5, pp.2740-2742, 1997. ,
DOI : 10.1109/20.617715
Decoding Punctured Reed?Solomon Codes up to the Singleton Bound, International ITG Conference on Source and Channel Coding (SCC), 2008. ,
Linear-Algebraic List Decoding of Folded Reed-Solomon Codes, 2011 IEEE 26th Annual Conference on Computational Complexity, pp.77-85, 2011. ,
DOI : 10.1109/CCC.2011.22
A generalization of the Berlekamp-Massey algorithm for multisequence shift-register synthesis with applications to decoding cyclic codes, IEEE Transactions on Information Theory, vol.37, issue.5, pp.1274-1287, 1991. ,
DOI : 10.1109/18.133246
Fast Multi-Sequence Shift-Register Synthesis with the Euclidean Algorithm, Adv. Math. of Comm, vol.5, issue.4, pp.667-680, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00647586
The Theory of Error-Correcting Codes, 1988. ,
Generalizing bounds on the minimum distance of cyclic codes using cyclic product codes, 2013 IEEE International Symposium on Information Theory, pp.126-130, 2013. ,
DOI : 10.1109/ISIT.2013.6620201
URL : https://hal.archives-ouvertes.fr/hal-00828083
Decoding of parallel Reed-Solomon codes with applications to product and concatenated codes, Proceedings. 1998 IEEE International Symposium on Information Theory (Cat. No.98CH36252), p.55, 1998. ,
DOI : 10.1109/ISIT.1998.708636
Collaborative Decoding of Interleaved Reed–Solomon Codes and Concatenated Code Designs, IEEE Transactions on Information Theory, vol.55, issue.7, pp.2991-3012, 2009. ,
DOI : 10.1109/TIT.2009.2021308
List Decoding Tensor Products and Interleaved Codes, SIAM Journal on Computing, vol.40, issue.5, pp.1432-1462, 2011. ,
DOI : 10.1137/090778274
URL : http://arxiv.org/abs/0811.4395
