Reports
A Sensitivity Equation Method for Unsteady Compressible Flows: Implementation and Verification
Régis Duvigneau 1
1 ACUMES - Analysis and Control of Unsteady Models for Engineering Sciences
CRISAM - Inria Sophia Antipolis - Méditerranée
Abstract : Sensitivity analysis is a key element in a design optimization procedure. Although the related theory and numerical implementation are well known for steady problems, the application to unsteady partial differential equations, in particular in fluid mechanics, is still an active research area. In this report, a sensitivity equation method is described, in the context of compressible Navier-Stokes equations, and an efficient numerical implementation is proposed. The resulting approach is verified for two- and three-dimensional problems of increasing complexity.
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/hal-01161957
Contributor : Régis Duvigneau Connect in order to contact the contributor
Submitted on : Tuesday, June 9, 2015 - 2:38:25 PM
Last modification on : Saturday, June 25, 2022 - 11:16:40 PM
Long-term archiving on: : Tuesday, April 25, 2017 - 6:00:07 AM
File
RR-8739.pdf
Identifiers
  • HAL Id : hal-01161957, version 1
Citation
Régis Duvigneau. A Sensitivity Equation Method for Unsteady Compressible Flows: Implementation and Verification. [Research Report] RR-8739, Inria. 2015, pp.34. ⟨hal-01161957⟩
Share
Metrics
Record views
202
Files downloads
166
