A robust and stable numerical scheme for a depth-averaged Euler system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We propose an efficient numerical scheme for the resolution of a non-hydrostatic Saint-Venant type model. The model is a shallow water type approximation of the incompressbile Euler system with free surface and slightly differs from the Green-Naghdi model. The numerical approximation relies on a kinetic interpretation of the model and a projection-correction type scheme. The hyperbolic part of the system is approximated using a kinetic based finite volume solver and the correction step implies to solve an elliptic problem involving the non-hydrostatic part of the pressure. We prove the numerical scheme satisfies properties such as positivity, well-balancing and a fully discrete entropy inequality. The numerical scheme is confronted with various time-dependent analytical solutions. Notice that the numerical procedure remains stable when the water depth tends to zero.
euler_av_dis.pdf (543.21 Ko) Télécharger le fichier
hal-01162109 , version 1 (09-06-2015)
hal-01162109 , version 2 (22-06-2015)
hal-01162109 , version 3 (14-09-2015)
N. Aissiouene, Marie-Odile Bristeau, Edwige Godlewski, Jacques Sainte-Marie. A robust and stable numerical scheme for a depth-averaged Euler system. 2015. ⟨hal-01162109v1⟩
342 Consultations
437 Téléchargements
