A note about the geometric optimal control of the copepod swimmer
The objective of this note is to made preliminary remarks concerning the optimal locomotion of the Copepod swimmer described by a simple model concerning swimming at low Reynolds number, in the framework of Sub-Riemannian geometry. In particular the role of both normal and abnormal geodesics is related to observed geometric motions.
Optimisation et contrôle [math.OC]
