Pointwise circumscription is equivalent to predicate completion (sometimes) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1988
Yves Moinard
  • Fonction : Auteur
  • PersonId : 869101
Two ways of minimizing positive information are predicate completion, which comes from logic programming theory, and circumscription, which is one of the best known methods of non-monotonic reasoning. Here, it is shown that, under certain hypothesis, there is equivalence between predicate completion and a special kind of circumscription.
PointwiseCirc88medium.pdf (5.32 Mo) Télécharger le fichier
TransPointwiseCirc88.pdf (2.5 Mo) Télécharger le fichier
Format : Présentation
hal-01162532 , version 1 (10-06-2015)
  • HAL Id : hal-01162532 , version 1
Yves Moinard. Pointwise circumscription is equivalent to predicate completion (sometimes). Fifth International Conference of Logic Programming (ICLP 88), Aug 1988, Seattle, United States. ⟨hal-01162532⟩
170 Consultations
52 Téléchargements
