Reasoning in description logics with variables: preliminary results regarding the EL logic. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper studies the extension of description logics with variables ranging over infinite domains of concept names and role names. As a preliminary work, we consider more specifically the extension of the logic EL with variables and we investigate in this context two reasoning mechanisms, namely compliance (a kind of matching) and pattern containment. The main technical results are derived by establishing a correspondance between the EL logic and finite variable automata.
Akroun-Nourine-Toumani-15.pdf (508.18 Ko) Télécharger le fichier
hal-01163342 , version 1 (21-09-2020)
  • HAL Id : hal-01163342 , version 1
Lakhdar Akroun, Lhouari Nourine, Farouk Toumani. Reasoning in description logics with variables: preliminary results regarding the EL logic.. 28th International Workshop on Description Logics, Jun 2015, Athenes, Greece. pp.12. ⟨hal-01163342⟩
303 Consultations
164 Téléchargements
