Multichannel audio source separation with deep neural networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2016
Séparation de sources audio multicanale par réseaux de neurones profonds
This research report addresses the problem of multichannel audio source separation. We propose a deep neural network (DNN) based framework where the source spectra are estimated using DNNs and used in a multichannel filter. The filter is derived using an iterative expectation-maximization (EM) algorithm, in which spatial covariance matrices encode the spatial information. We present an extensive experimental study to show the impact of different design choices on the performance of the proposed technique. We consider different cost functions for the training of DNNs, namely Itakura-Saito (IS) divergence, Cauchy cost function, phase-sensitive cost function, and mean squared error (MSE). The use of probabilistically motivated cost function, such as the IS divergence, is interesting because it leads to a mathematically rigorous EM interpretation for the proposed framework. We also study the number of EM iterations and the use of multiple DNNs, where each DNN aims to improve the spectra estimated by the preceding EM iteration. Finally, we present its application to a speech enhancement problem. The experimental results show the benefit of the proposed multichannel approach over a single-channel DNN-based approach.
Ce rapport porte sur le problème de la séparation de sources audio multicanal. Nous proposons un cadre basé sur les réseaux de neurones profonds (deep neural networks ou DNNs) où les spectres des sources sont estimé par des DNNs et utilisés dans un filtre multicanal. Ce filtre est obtenu en utilisant un algorithme espérance-maximisation (EM), dans lequel des matrices de covariance spatiale encodent l'information spatiale. Nous présentons une étude expérimentale approfondie montrant l'impact de différents choix sur la performance de la technique proposée. Nous considérons différentes fonctions de coût pour l'apprentissage des DNNs: la divergence d'Itakura-Saito (IS) divergence, la fonction de coût de Cauchy, une fonction de coût sensible à la phase, et l'erreur quadratique moyenne (mean squared error ou MSE). L'usage de fonctions de coût motivées par la théorie des probabilités, comme la divergence IS et la fonction de coût de Cauchy, est intéressant car il permet une interprétation probabiliste rigoureuse de l'algorithme EM proposé. Nous étudions aussi le nombre d'itérations EM et l'usage de DNNs multiples, où chaque DNN vise à améliorer les spectres estimés à l'itération EM précédente. Enfin, nous présentons l'application de cette technique à un problème de rehaussement de la parole. Les résultats expérimentaux montrent le potentiel de l'approche multicanal proposée par rapport à une approche basée sur les DNNs à un seul canal.
RR-8740v2.pdf (832.88 Ko) Télécharger le fichier
hal-01163369 , version 1 (12-06-2015)
hal-01163369 , version 2 (16-07-2015)
hal-01163369 , version 3 (05-02-2016)
hal-01163369 , version 4 (12-05-2016)
hal-01163369 , version 5 (21-06-2016)
  • HAL Id : hal-01163369 , version 4
Aditya Arie Nugraha, Antoine Liutkus, Emmanuel Vincent. Multichannel audio source separation with deep neural networks. [Research Report] RR-8740, Inria. 2016. ⟨hal-01163369v4⟩
Collections
INRIA-RRRT
2143 Consultations
10550 Téléchargements
