Speech enhancement with LSTM recurrent neural networks and its application to noise-robust ASR - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We evaluate some recent developments in recurrent neural network (RNN) based speech enhancement in the light of noise-robust automatic speech recognition (ASR). The proposed framework is based on Long Short-Term Memory (LSTM) RNNs which are discriminatively trained according to an optimal speech reconstruction objective. We demonstrate that LSTM speech enhancement, even when used ' na¨vely ' as front-end processing, delivers competitive results on the CHiME-2 speech recognition task. Furthermore, simple, feature-level fusion based extensions to the framework are proposed to improve the integration with the ASR back-end. These yield a best result of 13.76 % average word error rate, which is, to our knowledge, the best score to date.
weninger_LVA15.pdf (295.58 Ko) Télécharger le fichier
hal-01163493 , version 1 (13-06-2015)
  • HAL Id : hal-01163493 , version 1
Felix Weninger, Hakan Erdogan, Shinji Watanabe, Emmanuel Vincent, Jonathan Le Roux, et al.. Speech enhancement with LSTM recurrent neural networks and its application to noise-robust ASR. 12th International Conference on Latent Variable Analysis and Signal Separation (LVA/ICA), Aug 2015, Liberec, Czech Republic. ⟨hal-01163493⟩
6117 Consultations
9104 Téléchargements
