A significance cache for accelerating global illumination, Forum, vol.31, issue.3, 2012. ,
Importance-driven Monte Carlo light tracing, EGWR. 1995, pp.188-197 ,
Implementing Vertex Connection and Merging Light transport simulation with vertex connection and merging, Tech. rep. ACM Trans. Graph, vol.31, issue.10, pp.6-11, 2012. ,
Joint importance sampling of low-order volumetric scattering, ACM Trans. on Graph, vol.32, issue.2, p.6, 2013. ,
Importance caching for complex illumination, Comp. Graph. Forum, vol.31, issue.2, 2007. ,
Probabilistic Connections for Bidirectional Path Tracing Multiplexed metropolis light transport, ACM Trans. on Graph, vol.33, issue.100 11, p.4, 2014. ,
Matrix rowcolumn sampling for the many-light problem, In ACM Trans. on Graph, vol.26, issue.2, p.26, 2007. ,
A path space extension for robust light transport simulation, ACM Trans. on Graph, vol.31, issue.10, pp.191-202, 2012. ,
Illumination in the presence of weak singularities, Monte Carlo and Quasi-Monte Carlo Methods, 2004. ,
Bi-directional path tracing, CompuGraphics, 1993. ,
Virtual ray lights for rendering scenes with participating media, ACM Trans. on Graph, vol.31, issue.60 2, pp.4-2012 ,
Combinatorial bidirectional path-tracing for efficient hybrid CPU/GPU rendering, Comp. Graph. Forum, vol.30, issue.2 2, 2011. ,
Improving SIMD efficiency for parallel Monte Carlo light transport on the GPU, High Performance Graph, 2011. ,
Bidirectional estimators for light transport, EGWR. 1995. 1 ,
Optimally combining sampling techniques for Monte Carlo rendering, SIGGRAPH'95, 1995. ,
On-line learning of parametric mixture models for light transport simulation, ACM Trans. on Graph, vol.33, p.4, 2014. ,
Lightcuts: a scalable approach to illumination, SIGGRAPH '05, 2005. ,
Embree ray tracing kernels for CPUs and the Xeon Phi architecture, ACM SIGGRAPH 2013 Talks, pp.44-51, 2013. ,
