Advocatus diaboli -exploratory enrichment of ontologies with negative constraints, Int. Conf. Knowledge Engineering and Knowledge Management (EKAW), LNAI 7603, pp.42-56, 2012. ,
Learning disjointness for debugging mappings between lightweight ontologies, LNCS, vol.5268, pp.93-108, 2008. ,
Creating semantic web contents with Protege-2000, Intelligent Systems, issue.2, pp.16-60, 2001. ,
Validating ontologies with OOPS ! In Knowledge Engineering and Knowledge Management (EKAW) OWL pizzas : Practical experience of teaching OWL-DL : Common errors & common patterns, Engineering Knowledge in the Age of the Semantic Web, pp.267-281, 2004. ,
