Deembedding of filters in multiplexers via rational approximation and interpolation - Archive ouverte HAL Access content directly
Journal Articles International Journal of RF and Microwave Computer-Aided Engineering Year : 2015
(1) , (2) , (1) , (1) , (3)
1
2
3
In this paper we present a method to recover electrical parameters of filters embedded in a multiplexer for which scattering measurements are given. Unlike other approaches proposed for this problem, this method does not require a priori knowledge of the scattering parameters of the junction. This feature renders the procedure well suited for tuning purposes or for fault diagnosis. Technically the algorithm starts with a rational approximation step, in order to derive a rational representation of certain scattering parameters of the multiplexer. This representation is then used in a second step to identify the electrical model of each filter. This second step relies on a rational interpolation technique used to extract the filter's responses.
PaperWileyIJRFMiCAE12.pdf (649.85 Ko) Télécharger le fichier
Dates and versions
hal-01165529 , version 1 (17-01-2020)
Identifiers
  • HAL Id : hal-01165529 , version 1
Cite
Fabien Seyfert, Matteo Oldoni, Martine Olivi, Sanda Lefteriu, D. Pacaud. Deembedding of filters in multiplexers via rational approximation and interpolation. International Journal of RF and Microwave Computer-Aided Engineering, 2015, pp.7. ⟨hal-01165529⟩
227 View
124 Download
Share
