Improved Regret Bounds for Undiscounted Continuous Reinforcement Learning - Archive ouverte HAL Access content directly
Conference Papers Year :
We consider the problem of undiscounted reinforcement learning in continuous state space. Regret bounds in this setting usually hold under various assumptions on the structure of the reward and transition function. Under the assumption that the rewards and transition probabilities are Lipschitz, for 1-dimensional state space a regret bound of $\tilde{O}(T^{\frac{3}{4}})$ after any $T$ steps has been given by \citet{contrl}. Here we improve upon this result by using non-parametric kernel density estimation for estimating the transition probability distributions, and obtain regret bounds that depend on the smoothness of the transition probability distributions. In particular, under the assumption that the transition probability functions are smoothly differentiable, the regret bound is shown to be $\tilde{O}(T^{\frac{2}{3}})$ asymptotically for reinforcement learning in 1-dimensional state space. Finally, we also derive improved regret bounds for higher dimensional state space.
Not file
Dates and versions
hal-01165966 , version 1 (21-06-2015)
Identifiers
  • HAL Id : hal-01165966 , version 1
Cite
Kailasam Lakshmanan, Ronald Ortner, Daniil Ryabko. Improved Regret Bounds for Undiscounted Continuous Reinforcement Learning. International Conference on Machine Learning (ICML), Jul 2015, Lille, France. ⟨hal-01165966⟩
7154 View
0 Download
Share
