An aperiodic set of 11 Wang tiles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Combinatorics Année : 2021
We present a new aperiodic tileset containing 11 Wang tiles on 4 colors, and we show that this tileset is minimal, in the sense that no Wang set with either fewer than 11 tiles or fewer than 4 colors is aperiodic. This gives a definitive answer to the problem raised by Wang in 1961.
1506.06492.pdf (506.34 Ko) Télécharger le fichier
hal-01166053 , version 1 (22-06-2015)
hal-01166053 , version 2 (22-06-2015)
hal-01166053 , version 3 (13-12-2020)
hal-01166053 , version 4 (21-11-2021)
Emmanuel Jeandel, Michael Rao. An aperiodic set of 11 Wang tiles. Advances in Combinatorics, 2021, ⟨10.19086/aic.18614⟩. ⟨hal-01166053v4⟩
481 Consultations
1126 Téléchargements
