Ocean Turbulent Dynamics at Superresolution From Optimal Multiresolution Analysis and Multiplicative Cascade - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Geoscience and Remote Sensing Année : 2015
The synoptic determination of ocean circulation using the data acquired from space, with a coherent depiction of its turbulent characteristics, remains a fundamental challenge in oceanography. This determination has the potential of revealing all aspects of the ocean dynamic variability on a wide range of spatiotemporal scales and will enhance our understanding of ocean–atmosphere exchanges at superresolution, as required in the present context of climate change. Here, we show a four-year time series of spatial superresolution (4 km) turbulent ocean dynamics generated from satellite data using emerging ideas in signal processing coming from nonlinear physics, low-resolution dynamics, and superresolution oceanic sea surface temperature data acquired from optical sensors. The method at its core consists in propagating across the scales the low-resolution dynamics in a multiresolution analysis computed on adimensional critical transition information.
Fichier non déposé
hal-01166170 , version 1 (22-06-2015)
Joël Sudre, Hussein Yahia, Oriol Pont, Véronique Garçon. Ocean Turbulent Dynamics at Superresolution From Optimal Multiresolution Analysis and Multiplicative Cascade. IEEE Transactions on Geoscience and Remote Sensing, 2015, 53 (11), pp.12. ⟨10.1109/TGRS.2015.2436431⟩. ⟨hal-01166170⟩
357 Consultations
0 Téléchargements
