M. W. Hwu and W. , Tangram: a high-level language for performance portable code synthesis, Programmability Issues for Heterogeneous Multicores, 2015.
C. , J. Paris, S. And-durand, and F. , Real-time edgeaware image processing with the bilateral grid, ACM Trans. Graph, vol.26, issue.103, pp.1-103, 2007.
G. , M. I. Thies, W. Karczmarek, M. Lin, J. Meli et al., A stream compiler for communication-exposed architectures, ASPLOS, pp.291-303, 2002.
H. , F. Ruckdeschel, H. Dutta, H. And-teich, and J. , PARO: Synthesis of hardware accelerators for multidimensional dataflow-intensive applications, Reconfigurable Computing: Architectures, Tools and Applications, pp.287-293, 2008.
H. , P. And-lawson, and J. , A language for shading and lighting calculations, Computer Graphics (Proceedings of SIGGRAPH 90), pp.289-298, 1990.
H. , K. Sun, J. And-tang, and X. , Guided image filtering, IEEE Trans. Pattern Anal. Mach. Intell, vol.35, issue.6, pp.1397-1409, 2013.
H. , J. Scheuermann, T. Coombe, G. Singh, M. And-lastra et al., Fast summed-area table generation and its applications, Computer Graphics Forum, vol.24, issue.3, pp.547-555, 2005.
H. , T. , Y. , G. And-tang, and G. , A fast twodimensional median filtering algorithm, pp.13-18, 1979.
K. , R. M. Miller, R. E. And-winograd, and S. , The organization of computations for uniform recurrence equations, Journal of the ACM, vol.14, issue.3, pp.563-590, 1967.
K. , A. Nakano, K. , A. Ito, and Y. , Parallel algorithms for the summed area table on the asynchronous hierarchical memory machine, with GPU implementations, International Conference on Parallel Processing, pp.251-260, 2014.
K. , M. And, and J. Solomon, Smoothed local histogram filters, ACM Trans. Graph, vol.29, issue.100, pp.1-10010, 2010.
K. , P. M. And, and H. S. Stone, A parallel algorithm for the efficient solution of a general class of recurrence equations, IEEE Transactions on Computers C, vol.22, issue.8, pp.786-793, 1973.
L. , T. Paulin, P. And-flamand, and E. , A novel compilation approach for image processing graphs on a many-core platform with explicitly managed memory, International Conference on Compilers, Architecture and Synthesis for Embedded Systems (CASES), pp.1-10, 2013.
M. , W. R. Glanville, R. S. Akeley, K. And-kilgard, and M. J. , Cg: A system for programming graphics hardware in a C-like language, ACM Trans. Graph, vol.22, pp.3-896, 2003.
M. , R. Reiche, O. Hannig, F. Teich, J. Korner et al., HIPAcc: A domain-specific language and compiler for image processing, IEEE Transactions on Parallel and Distributed Systems, 2015.
M. , R. T. Vasista, V. And-bondhugula, and U. , Polymage: Automatic optimization for image processing pipelines, ASPLOS, pp.429-443, 2015.
N. , D. Maximo, A. Lima, R. S. And-hoppe, and H. , GPU-efficient recursive filtering and summed-area tables, ACM Trans. Graph, vol.30, issue.176, pp.1-17612, 2011.
O. , G. Rompf, T. Stojanov, A. Odersky, M. And-p-¨-uschel et al., Spiral in Scala: Towards the systematic construction of generators for performance libraries, SIGPLAN Not, vol.49, pp.3-125, 2013.
P. , S. And-h-´-ebert, and P. , Median filtering in constant time, IEEE Trans. Img. Proc, vol.16, issue.9, pp.2389-2394, 2007.
R. , J. Adams, A. Paris, S. Levoy, M. Ama-rasinghe et al., Decoupling algorithms from schedules for easy optimization of image processing pipelines, ACM Trans. Graph, vol.31, issue.32, pp.1-3212, 2012.
R. , J. Barnes, C. Adams, A. Paris, S. Du-rand et al., Halide: a language and compiler for optimizing parallelism, locality, and recomputation in image processing pipelines, PLDI, pp.519-530, 2013.
R. , R. And-mcclellan, and J. , Efficient approximation of Gaussian filters, IEEE Trans. Sig. Proc, vol.45, issue.2Feb, pp.468-471, 1997.
R. , M. Holewinski, J. And-grover, and V. , Forma: A DSL for image processing applications to target GPUs and multi-core CPUs, GPGPU, pp.109-120, 2015.
R. , D. And-thévenazth´thévenaz, and P. , GPU prefilter for accurate cubic b-spline interpolation, The Computer Journal, 2010.
S. , S. Harris, M. Zhang, Y. And-owens, and J. D. , Scan primitives for GPU computing, Symposium on Graphics Hardware, pp.97-106, 2007.
S. , S. And-hush, and D. , Digital Signal Processing with Examples in MATLAB, Second Edition, Electrical Engineering & Applied Signal Processing Series, 2002.
S. , W. And-mitra, and S. , Efficient multi-processor implementation of recursive digital filters, IEEE Conference on Acoustics, Speech and Signal Processing, pp.257-260, 1986.
T. , W. Karczmarek, M. And-amarasinghe, and S. P. , Streamit: A language for streaming applications, International Conference on Compiler Construction, pp.179-196, 2002.
V. Vliet, L. J. Young, I. T. And-verbeek, and P. W. , Recursive Gaussian derivative filters, Proceedings. Fourteenth International Conference on Pattern Recognition (Cat. No.98EX170), pp.509-514, 1998.
DOI : 10.1109/ICPR.1998.711192
