O-snap, ACM Transactions on Graphics, vol.32, issue.1, 2013. ,
DOI : 10.1145/2421636.2421642
A Non-Local Algorithm for Image Denoising, 2005 IEEE Computer Society Conference on Computer Vision and Pattern Recognition (CVPR'05), 2005. ,
DOI : 10.1109/CVPR.2005.38
The 3D Hough Transform for plane detection in point clouds: A review and a new accumulator design, 3D Research, vol.2, issue.2 2, 2011. ,
A benchmark for surface reconstruction, 2013. ,
Fast and Robust Normal Estimation for Point Clouds with Sharp Features, Computer Graphics Forum, vol.39, issue.5, 2012. ,
DOI : 10.1111/j.1467-8659.2012.03181.x
Robust piecewise-planar 3D reconstruction and completion from largescale unstructured point data, CVPR, 2010. ,
Computer and Machine Vision: Theory, Algorithms, Practicalities, 2005. ,
Random sample consensus: A paradigm for model fitting with applications to image analysis and automated cartography, Communications of the ACM, vol.24, issue.6 2, 1981. ,
A dense map building approach from spherical rgbd images, VISAPP (3), 2014. ,
Fast range image segmentation and smoothing using approximate surface reconstruction and region growing, In IAS, vol.194, issue.2 3, 2012. ,
A method and means for recognizing complex patterns, U.S. Patent No, vol.3, issue.2, p.69654, 1962. ,
Semantic labeling of 3d point clouds for indoor scenes, NIPS, 2011. ,
Maximizing parallelism in the construction of bvhs, octrees, and k-d trees, Proceedings of the EURO- GRAPHICS Conference on High Performance Graphics 2012, pp.33-37, 2012. ,
Surface Reconstruction through Point Set Structuring, 2013. ,
Creating large-scale city models from 3D-point clouds: a robust approach with hybrid representation, 2012. ,
Globfit: Consistently fitting primitives by discovering global relations, p.9, 2011. ,
The random cluster model for robust geometric fitting, CVPR, 2012. ,
Pipe-run extraction and reconstruction from point clouds, ECCV, 2014. ,
Segmentation of point clouds using smoothness constraint, ISPRS, vol.36, issue.3, p.5, 2006. ,
Completion and reconstruction with primitive shapes, p.2, 2009. ,
Adaptive partitioning of urban facades, 2011. ,
Interactive 3d architectural modeling from unordered photo collections, 2008. ,
DOI : 10.1145/1409060.1409112
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.153.3433
Efficient RANSAC for point-cloud shape detection, p.9, 2007. ,
Recognising structure in laser scanner point clouds, ISPRS, vol.46, issue.8 1, 2004. ,
Towards high-resolution large-scale multi-view stereo Localizing 3d cuboids in single-view images, CVPR (Miami NIPS, 2009. ,
5D building modeling by discovering global regularities, CVPR, 2012. ,
