Cartographie de la vulnérabilité aux phénomènes volcaniques et aux lahars du Pinatubo(Philippines). Cas du bassin de la rivière Pasig-Potrero (Province de Pampanga) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Pangea infos Année : 1998
Mapping of population vulnerability to volcanic hazards and lahars of Mount Pinatubo (Philippines). Case study of Pasig-Potrero river basin (Pampanga province)
Jean-Christophe Gaillard
Robert d'Ercole
Frédéric Leone
This study aims at assessing the population vulnerability in the Pasig-Potrero River basin threatened by the recurrent lahars of Mt Pinatubo volcano (Philippines) subsequent to its 1991 eruption. A survey carried out between February and March 1998 enabled us to define and to map different levels of risk perception, the quality of the potential behaviors in the event of further lahars and of the demeanors in case of evacuation order. It was then possible to work out a typology and a cartography of human vulnerability in this study area. This study points out that, even though the risk perception is quite high, some problems remain, notably concerning warning and behaviors in case of evacuation. This work is part of a larger framework including population vulnerability assessment around Mt Pinatubo (social and institutional vulnerability). It also aims at estimating the effects, notably the territorial consequences, occurred as a result of a crisis linked to the volcano and its lahars, and that has been lasting for eight years. These results should allow to elaborate some risk and disaster scenarios. They are intended to be used as operational purposes in crises management such as relief arrangement, land use planning.
Cette étude a pour objectif d'évaluer la vulnérabilité des populations du bassin de la rivière Pasig-Potrero menacé par les lahars récurrents du volcan Pinatubo (Philippines) suite à l'éruption de 1991. A partir d'une campagne d'enquêtes sur le terrain, réalisée entre février et mars 1998, on a pu définir et cartographier différents niveaux de perception du risque, la qualité des comportements potentiels face aux lahars ainsi que des attitudes en cas d'ordre d'évacuation. Ces données ont ensuite permis de réaliser une typologie et une cartographie de la vulnérabilité dans le secteur d'étude. Il en ressort que si la perception du risque est assez élevée, des problèmes subsistent, notamment en matière d'alerte et de comportements en cas d'évacuation. La qualité de l'alerte a aussi montré, dans le passé, des carences qu'il convient aujourd'hui de combler. Ce travail s’inscrit dans un cadre plus large d'évaluation de la vulnérabilité des populations face au volcan Pinatubo (vulnérabilité sociale, institutionnelle...) el des conséquences, notamment territoriales, de huit années de crises liées à l'éruption, puis aux lahars. Ces conclusions peuvent guider l'élaboration de scénarios de risque et de catastrophe, utiles à des fins opérationnelles (planification des secours, aide à la gestion des crises, aménagement du territoire...).
Gaillard D'Ercole Leone 1998 - Cartographie de la vulnérabilité des populations Pinatubo Philippines.pdf (6.33 Mo) Télécharger le fichier
hal-01169313 , version 1 (29-06-2015)
  • HAL Id : hal-01169313 , version 1
Jean-Christophe Gaillard, Robert d'Ercole, Frédéric Leone. Cartographie de la vulnérabilité aux phénomènes volcaniques et aux lahars du Pinatubo(Philippines). Cas du bassin de la rivière Pasig-Potrero (Province de Pampanga). Pangea infos, 1998, 29-30, pp.5-19. ⟨hal-01169313⟩
356 Consultations
113 Téléchargements
