Anonymous Obstruction-free $(n,k)$-Set Agreement with $n-k+1$ Atomic Read/Write Registers
Accord $k$-ensembliste asynchrone et anonyme avec $(n-k+1)$ registres atomiques
The $k$-set agreement problem is a generalization of the consensus problem.
Namely, assuming each process proposes a value, each non-faulty process
has to decide a value such that each decided value was proposed,
and no more than $k$ different values are decided.
This is a hard problem in the sense that
it cannot be solved in asynchronous systems as soon as $k$ or more processes
may crash. One way to circumvent this impossibility consists in weakening
its termination property, requiring that a process terminates (decides)
only if it executes alone during a long enough period. This is the well-known
obstruction-freedom progress condition.
Considering a system of $n$ {\it anonymous asynchronous} processes, which
communicate through atomic {\it read/write registers only}, and where
{\it any number of processes may crash}, this paper addresses and solves
the challenging open problem of designing an obstruction-free
$k$-set agreement algorithm with $(n-k+1)$ atomic registers only.
From a shared memory cost point of view, this algorithm is the best
algorithm known so far, thereby establishing a new upper bound on the number
of registers needed to solve the problem (its gain is $(n-k)$
with respect to the previous upper bound). The algorithm is then extended to
address the repeated version of $(n,k)$-set agreement. As it is optimal
in the number of atomic read/write registers, this algorithm
closes the gap on previously established lower/upper bounds
for both the anonymous and non-anonymous versions of the repeated
$(n,k)$-set agreement problem. Finally,
for $1 \leq x\leq k < n$, a generalization suited to $x$-obstruction-freedom
is also described, which requires $(n-k+x)$ atomic registers only.
Cet article préente un algorithme asynchrone
qui résoud l'accord k-ensenbliste dans un système
de n processus asynchrones et anonymes communiquant
via $(n-k+1)$ registres atomiques du type lire/écrire,
et dans lequel un nombre quelconque d'entre eux peut s'arrêter
de façon inopinée (crash failure).
La propriété de vivacité garantie par l'algorithme est appelée "obstruction-freedom".
