Online Path Loss Estimation for Localization Using Large Aperture Array Signal Processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Roudy Dagher
In this paper, a novel array-based method to estimate the path loss exponent (PLE) is developed. The method is designed as a part of an automatic calibration step, prior to localization of a source transmitting in the near-far field of the array. The method only requires the knowledge of the ranges between the array elements. By making the antenna elements transmit in turn, the array response model in the near-far field is exploited to estimate the current environment PLE. Simulation results show that this method can achieve good performance with one transmission round. The performance of the PLE estimation is investigated in the context of source localization with a sensitivity analysis to the PLE estimation.
main.pdf (240.29 Ko) Télécharger le fichier
hal-01169710 , version 1 (13-11-2015)
  • HAL Id : hal-01169710 , version 1
Roudy Dagher, Nathalie Mitton. Online Path Loss Estimation for Localization Using Large Aperture Array Signal Processing. 23rd European Signal Processing Conference (EUSIPCO), EURASIP, Aug 2015, Nice, France. ⟨hal-01169710⟩
Collections
INRIA INRIA2
155 Consultations
123 Téléchargements
